I button — Parallax Forums
I button
edited 2003-02-10 17:33 in General Discussion
I also would like to see a method of reading the 1 wire buttons. I have
heard as well the stamp is to slow. Cant a simple ckt be built to send the 2
quick pulses the 1 wire needs,and then read in the data from the 1 wire
using a stamp? I wanted to red the 1 wire weather station with a stamp.
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
    edited 2003-02-09 15:13
    Have any of you successfully interface an I button with a stamp? I know the
    BS2P40 has a one wire connection.
    edited 2003-02-09 18:44
    Dallas/Maxim iButton interfacing is very simple with the BS2p family. The
    BS2p demo boards even have iButton sockets on them. That said, Dallas specs
    are sometimes difficult to deal with. We've taken care of the protocol
    stuff, the rest is up to you.
    Are you having a specific problem?
    -- Jon Williams
    -- Parallax
    In a message dated 2/9/2003 9:15:46 AM Central Standard Time,
    Trkeenan@a... writes:
    edited 2003-02-10 11:54
    No Problem yet. I didn't know if it was something I thought I could figure
    out easily.
    Tim
    Hi:
    As you mentioned, the BS2P40 has 1-Wire capability built in. Adding that
    capability to a BS2 requires adding hardware. Two options:
    1) Use the Dallas 8 pin surface mount DS2480b intended to help PCs cope with
    the precision demanded by 1-Wire processing. See:
    http://pdfserv.maxim-ic.com/arpdf/DS2480B.pdf
    the flow chart is on page 4.
    2) Use an 8 pin DIP co-processor complete with almost 30 example programs
    already written for the BS2 and covering these 1-Wire / iButton devices:
    iButton DS1971 EEPROM Memory
    iButton DS1992-4, 4k Memory, Real-Time clock, Counters
    iButton DS1996 64k Memory
    DS182x Family of Temperature sensors
    DS2401 Presence detector
    DS2405/6 PIO devices
    DS2422/3 RAM, Counters
    DS2430 EEPROM Memory
    S2890 Digital Potentiometers
    When told to search it also stores up to 8 of the 64 bit IDs in its own
    EEPROM. Then reference as #0-7 rather than feed 64 bits for each operation.
    Full info here:
    http://www.rhombus-tek.com/OneWire.htm also as .../OW.pdf
    Whether BS2P40 or either of the above
    www.maxim-ic.com will help with 1-Wire device samples.
    David H. Lawrence
    For Rhombus
    Sent: Sunday, February 09, 2003 7:13 AM
    Subject: [noparse][[/noparse]basicstamps] I button
    the
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.449 / Virus Database: 251 - Release Date: 1/27/03
