BS2sx Deaf but Alive
Hello all,
I have been trying to communicate with my BS2sx for some time now (i posted
an earlier message in March). I can tell the program is running because the
debug terminal receives an initialization message included in my code
topside.
*HOWEVER*
The processor seems to ignore the RESET button as well as any commands the
PC happens to send. Naturally, the s/w reports "stamp not responding" etc.
I have somehow this notion that the programme caused the Scenix chip to
enter a "deafness" mode of some sort, whereas it runs at power-up and then
locks in.
Then, what i may really need is an overriding command to force the uC to
stop and listen (i.e. accept a new programme). Just for the record, BX24
calls a similar procedure "rescue" - most deservingly!
Please, can someone advise on this (madly frustrating - needless to say)
situation. I am especially and directly addressing Parallax people: they
know the uC's various reset and power-down modes and may propose appropriate
signaling, in case my assumption is founded.
Thank you in advance,
George Chamilothoris
topside.
*HOWEVER*
locks in.
loop, like
start:
goto start.
-William
To: BasicStamps <basicstamps@egroups.com>
Sent: Friday, May 19, 2000 2:48 AM
Subject: [noparse][[/noparse]basicstamps] BS2sx Deaf but Alive
> Hello all,
posted
the
> topside.
> *HOWEVER*
> locks in.
appropriate
>topside.
the
etc.
Does it send the initialization message when you power up the chip, but not
when you press the reset button? If it is not responding to the reset
button, then maybe 1) the button is defective, 2) the reset pin on the chip
is stuck at the high level. Measure the voltage on the reset pin of the
bs2sx (pin 22) as you press reset. Also measure that same pin 22 voltage
as you bring the atn pin (pin 3) to a high +5 volt level.
-- Tracy
