bipolar stepper control — Parallax Forums
edited 2002-11-28 00:32 in General Discussion
I'm having trouble controlling a stepper with my stampII and I was
wondering if someone could help me out.
it's a 3V bipolar stepper that I'm trying to run from a L298 H bridge
and all I can get out of it is some vibrations, even if I set my step
time to 500ms
I've got one coil connected to outputs 1 and 2, and the other coil
connected to outputs 3 and 4. I had to ground the current sense pins on
the L298 to get it to work at all.
I've had a unipolar stepper working with this setup but never a bipolar.
is there something wrong with my setup, my sequencing, or is there a
problem trying to run the L298 at 3v? (I have the logic input connected
to 5v)
I'd appreciate any help you guys can provide.
thanks.
Jason Lavoie
    edited 2000-05-14 02:48
    Jason:
    I just looked at the L298 data sheet, and several thoughts come to mind:
    1) The bridge always drives with two transistors in series, and the spec
    indicates that the total drop will be ~2V. If you are supplying it with
    only 3V, this leaves only ~1V for the motor winding. Try running it with 5
    or 6 volts.
    2) The current sense pins must be grounded, either directly, or through a
    low value current sense resistor. If a resistor is used, you need even more
    supply voltage.
    3) Pin 9 (Vref) should be connected to 5V.
    4) Hopefully, you have the clamp diodes shown on the example circuits.
    If this doesn't help, maybe the phase sequence is wrong.
    Let us know how you make out,
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Saturday, May 13, 2000 6:09 PM
    Subject: [noparse][[/noparse]basicstamps] bipolar stepper control
    > time to 500ms
    > to 5v)
    > thanks.
    > Jason Lavoie
    edited 2000-05-14 06:10
    rjmca wrote:
    > Jason:
    > or 6 volts.
    although I was running it at 3v I was able to get the motor to turn by manually
    connecting each input to ground in sequence (touching wires together) I will
    bump it up to 5v though.
    > supply voltage.
    yup, grounded.
    done.
    I haven't added the diodes yet, would this cause it not to work at all?
    see answer to #1, I'm pretty sure I've got the sequence right. would it be a
    different sequence than a uni-polar stepper? (excluding half-steps)
    thanks, I'll see what happens.
    Jason
    edited 2000-05-14 06:24
    Hi Jason,
    Sent: Sunday, May 14, 2000 1:10 AM
    Subject: Re: [noparse][[/noparse]basicstamps] bipolar stepper control
    ** The lack of diodes shouldn't stop it from running, but it protects the
    IC.
    a
    ** Don't know...will sketch it out, hopefully tomorrow.
    Ray McArthur
    edited 2000-05-14 06:33
    The chip may not last very long without the diodes. You can get a pretty
    good spike when the magnetic flux in the coils collapse.
    > would it be a
    Here is the code I used in PICBasic Pro to drive a bipolar stepper through a
    L293D. PORTA.0 & PORTA.1 were hooked to one bridge and PORTA.2 & PORTA.3
    were hooked to the other. If you want to visualize the bits directly on the
    coils the coils are hooked up as AaBb. I would just uncomment the half step
    code and comment the full step stuff or visa versa. No real reason that the
    For loop is decrementing. It would work as well the other direction except
    the motor rotation would be reversed.
    myLoop:
    For i = 3 TO 0 STEP -1 'Full Step
    ' FOR i = 7 TO 0 STEP -1 'Half Step
    LookUp i,[noparse][[/noparse]%1010,%0110,%0101,%1001],mystep 'Full Step
    ' LOOKUP i,[noparse][[/noparse]%1010,%1000,%1001,%0001,%0101,%0100,%0110,%0010],mystep 'Half
    Step
    PORTA = mystep
    Pause mySpeed
    Next i
    GoTo myLoop
    Hope that helps you and get those diodes in place before the chip goes pop.
    Tim
    [noparse][[/noparse]Denver, CO]
    edited 2000-05-14 07:46
    hey thanks! I got it working.. I guess I just didn't have the right sequence.. I
    had something
    that looked similar, but for some reason it wasn't working.
    Jason Lavoie
    > myLoop:
    > ' LOOKUP
    > Step
    > PORTA = mystep
    > Pause mySpeed
    > Next i
    > GoTo myLoop
    > Tim
    edited 2000-05-15 02:54
    Hi Jason, Ray and Tim
    Information about stepper motors?
    The right sequence (for all types: unipolar, bipolar, etc.) and information
    about H-bridges (and protection diodes for your L298) are very very very
    good explained at:
    www.cs.uiowa.edu/~jones/step
    Ar
    edited 2000-05-15 04:15
    Aristides:
    I agree, we use that site, along with one from Thompson/Airpax as excellent
    references.
    Ray
    edited 2002-11-27 19:56
    Hi!
    I'm new to stamp world. I'm looking for code to drive a bipolar
    (4 wire) size 17 stepper motor. I've gotten the code for a unipolar
    motor, but a bipolar motor needs different sequencing.
    Any help would be most appreciated!
    Thank you and Happy Thanksgiving, U.S.A. [noparse]:)[/noparse]
    Ron Yost
    edited 2002-11-27 23:26
    Have a look at my web page on driving a stepper motor.
    It goes through some experiments I did in learning how to drive Stepper
    motors.
    Right at the end is a bipolar example - easily converted for a
    Microcontroller design.
    http://www.lennard.net.nz click on circuit ideas, then stepper motor (down
    the bottom of the links.
    Ben Lennard
    *ACSE, ACCE
    *National Certificate in Electronic Engineering
    *Diploma in Electronic and Software Engineering
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    > From: Ron Yost <musik42@c...>
    > Reply-To: basicstamps@yahoogroups.com
    > Date: Wed, 27 Nov 2002 11:56:32 -0800
    > Subject: [noparse][[/noparse]basicstamps] Bipolar stepper control
    > Hi!
    > Ron Yost
    > of the message will be ignored.
    >motors.
    Thank you very much!!
    I also found this one:
    http://www.geocities.com/SiliconValley/Foothills/4312/html/BasicStamp/stepp
    rog.txt
    Hope this hasn't been posted here a zillion times already. [noparse]:)[/noparse]
    Thanks, everyone.
    Ron
