Changing 5v to 3v logic
Does any one know how I can change the stamps 5 volt logic to 3v for a chip.
I need to change about 5 lines.
Is there some kind of buffer I can supply with 3v and will tolerate 5 on an
input, or do I just use resistors?
If you simply want to input 3V to a Stamp, you don't need to change
anything, the BS2 reads anything over 1.5 volts as a "1" and
everything below that as a "0".
-Chris
--- In basicstamps@egroups.com, "Michael Licitra" <mikel2@b...> wrote:
> Hi,
for a chip.
5 on an
> Thanks
> Mike
To: <basicstamps@egroups.com>
Sent: Thursday, May 11, 2000 8:11 PM
Subject: [noparse][[/noparse]basicstamps] Re: Changing 5v to 3v logic
> Mike,
> -Chris
> > Hi,
> for a chip.
> 5 on an
> > Thanks
> > Mike
If speed is important, take a look at Fairchild's NC7SZ86M. It's an XOR
gate, usable as a buffer, and it accepts 5V in while it's on a 3V supply.
Only one gate per (tiny) package, but Fairchild may have something
equivalent with multiple gates per package...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
-William
Sent: Thursday, May 11, 2000 8:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Changing 5v to 3v logic
> I need to go from the stamp to the 3v device.
> Thanks
> From: "Chris " <c_rosney@y...>
> > Mike,
> > -Chris
> > > Hi,
> > for a chip.
> > 5 on an
> > > Thanks
> > > Mike
might have read his message a bit better.
regards,
Sandor
William Cox wrote:
> You can just use PWM. Read the manual.
> -William
> [noparse][[/noparse]snip]
chip.
an
The CD4050 and CD4049 (inverting) are hex CMOS buffers that can accept
input voltages higher than their power supply. Resistors wouldn't be bad
either, especially using a couple of sip packages.
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
-William
Sent: Friday, May 12, 2000 8:50 AM
> I don't think he can for this purpose: instead of him reading the manual
you
> regards,
> Sandor
> > -William
parallel.
Bean, thitt@i...
