PCB Traces- Current Capacity? — Parallax Forums
edited 2000-05-11 20:31 in General Discussion
I wanna build a BS2 controlled speed control for 3 RC motors on one
board- much cheaper and funner than buying 3 separate units.
It'll use 3 MOSFET H bridges, passing about 20a/12v each...
Question: How do you determine appropriate trace width on PCBs for high
currents?
patmat
    edited 2000-05-11 19:18
    In a message dated 5/11/00 11:29:31 AM Central Daylight Time, pat.mat@a...
    writes:
    > currents?
    Check www.expresspcb.com -- they have a chart showing trace-width versus
    current.
    edited 2000-05-11 19:54
    Thanks for the tips. Something seems odd tho, when I look at a Futaba speed
    control, rated for many tens of amps, I see several paralleled MOSFETS, and the
    power traces aren't particularly wide... .150-.200" between 'FETs, widening out
    to maybe .300" where the 12 guage wire is soldered on... but there is a thick
    layer of solder on the traces...
    patmat
    edited 2000-05-11 19:59
    Or here's a thought: I can't see the top side, cause the 'FETs are jammed
    together and there's a big gob of glue, but maybe the traces are replicated on
    the top side, doubling the copper...
    > patmat
    > currents?
    12V and 20A? Use wire. Copper for that size will have to be very thick and very
    wide. 1/2" trace widths wouldn't be out of line. Your other option is to make
    the traces about 1/4" wide and solder a piece of 14awg house wire (solid of
    course) to it as added current carrying area. I've seen this one used in very
    high powered switching power supplies for the DC output rails, as well s sing it
    in a few of my own designs. Make sure your PCB is heavy duty, as soldering the
    wire to the trace will take a fair ammount of heat. Don't try this with anything
    smaller than a 200W gun either. I used the 500W iron at work. Not exactly the
    prettiest way to go, but it's a lot cheaper than the alternatives.
    -dave
    Discretion is the better part of valor
    dave paton http://homepage.mac.com/dpaton dave at ieee dot org
