Stamp Alarm System
Hi, I am tyring to spec out relays for an alarm system using the BSII.
Would anyone know the current rating for the parking lights on a 95 Camaro?
I need to use a stamp output to trigger a relay to flash the parking lights.
Or, would anyone know what exact relay I could use? I plan on using a
2N2222 to supply enough current for the relay. Thanks
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
They are one amp per filament. Most have two filaments,
individually selectable by the "buttons" on the base of the
bulb.
DLC
Dennis Clark http://www.verinet.com/~dlc/
"Be well, do good work and stay in touch" dlc@v...
most car alarms provide 10A for the parking lights, so your actual requirement
is likely less.
Jason
I think Potter & Brumfield's T90 series, or knock-off, is one of the most
common in high-current automotive applications...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
