Ming RF Modules — Parallax Forums
Ming RF Modules
edited 2000-05-09 03:50 in General Discussion
Has anyone used these modulels for serial comunications?
    edited 2000-05-08 21:43
    YES
    edited 2000-05-08 22:21
    I purchased the TX-66 transmitter, which is the more expensive unit with a
    SAW resonator, hoping for better stability than the standard LC module. The
    receiver is the RX-66 super-regen. Performance and workmanship was very
    poor. Even at 10' range, the received signal dropped out as surrounding
    objects moved around. The low logic level from the receiver was ~1 volt,
    the high level was OK. I used the recommended 9" antenna on both units, and
    tuning the receiver as recommended did no good. I tried to phone Ming
    several times, but there was no answer. If I recall correctly, they didn't
    reply to email either.
    Several others on this list had no problems, but I believe they used the
    cheaper LC transmitter. I gave up and bought a set from Ramsey. They cost
    more, but the tx uses a SAW filter, and the rx is superhet. The received
    signal is solid at 100'. My only complaint is that the rx is supposed to
    work at 5 volts, but it is marginal; does quite well at =>6 volts.
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Monday, May 08, 2000 3:41 PM
    Subject: [noparse][[/noparse]basicstamps] Ming RF Modules
    I have experimented with using the Ming RF modules
    in serial applications, but they tend to be unstable
    with varying environmental conditions such as temperature
    changes, rain, and traffic in the immediate area.
    If you're looking for [noparse][[/noparse]solid] RF components for serial applications
    the Linx Technologies LC RF modules are exceptional.
    The Ming RF modules work very well for applications that
    use the Holtek encoder/decoder ICs, but they don't perform
    [noparse][[/noparse]reliably] for serial applications.
    -Bruce
    http://www.rentron.com
    Sent: Monday, May 08, 2000 1:41 PM
