Sharp GP2D05 PIR Help! Stamp code keeps loopin (fixed sort of)
Dear Al, Dennis and all,
I changed the battery I was using to power the stamp, and now it no
longer loops
but now I keep getting eratic 0 and 1 s on the debug screen. So I have
to assume this is a hardware problem. The sensor doesn't respond to
movement like it did.
Thanks for all your advice.
Kath
longer loops
Kath
to it? I wouldn't be too quick to blame hardware failure. In my experience,
90% of the time I have loosened a connection, or pulled a wire out or done
something like that -- the simpler the problem, the harder it is to find --
usually.
Can you hook the sensor up to a scope and verify that it works the way you
expect? If you really think the Stamp input is to blame, try another input
pin -- I find that very unlikely though.
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/pak5.htm
> From: Kath [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cEfXxHegigcCmzejaYP05j6zEnV38VRjWRAW3c-scdX-z5m632p4zvRyhuLMediU5ScYXHguZLJ_HXRm_9Z6eg]kath@i...[/url
> Sent: Monday, May 01, 2000 11:36 AM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Sharp GP2D05 PIR Help! Stamp code keeps
> longer loops
> Kath
