Sharp GP2D05 PIR Help! Stamp code keeps looping! — Parallax Forums
edited 2000-04-30 18:38 in General Discussion
Hi All,
Have a problem using the Sharp GP2D05 and Basic Stamp2.
I modified the example code from Acroname (see below) that came with
the kit. This worked fine and I got a reading from the Sharp PIR.
However, because I wanted to use data logging activex control to save
the readings to a log file I decided I need to use SEROUT. So I thought
I would test another program that uses SEROUT on the basic stamp(2). I
used an example from Al Williams book " Microcontroller projects with
Basic Stamps" - ( pp126 Sample Program.).
The SEROUT example used pin 16 and included SERIN commands. The
problem is that since I ran the SEROUT example on the Stamp the modified
example code from Acroname doesn't work. It stops at the line that reads
in from the sensor to a variable.
Then repeatedly goes back to "DEBUG Start". I think my sensor has blown
as a result of the SERIN commands. But I don't know. Can sending SERIN
commands to pin 16 blow a PIR that has input connection to pin 15?
Any ideas on what else might cause the problem?
Gratefull for any suggestions.
The two examples are listed below.
****** the modified acroname code follows******
' variable declarations
val05 var byte ' value where reading is stored
i var byte ' count variable for loop
' constant declarations
cl con 14 ' pin 14 is output (clock)
dt con 15 ' pin 15 is the input (data)
' I/O pin setup for detector
INPUT dt ' make pin 15 the input
HIGH cl ' make pin 14 output and high
DEBUG "Start", CR ' indicate beginning
FOR i = 1 TO 100
GOSUB read05 ' take reading
DEBUG dec val05, CR ' display result
PAUSE 100 ' stall so display readable
NEXT
DEBUG "Finish", CR ' indicate end
END ' stop Stamp when done
' subroutine read05
' This subroutine takes a reading from the connected
' GP2D05 detector and stores the value in "val05".
' Any two pins can be used. Set "dt" to the data line
' of the GP2D05 (pin 3 on JST connector, yellow wire).
' Set cl to the clock line of the GP2D05 (pin 1 on the
' JST connector, green wire). Also, the IN15 needs
' to be set to the correct variable for the data pin
' (data line).
read05:
LOW cl ' turn on detector for reading
DEBUG " detector on ", CR
PAUSE 56 ' wait 56ms for detector to read
val05 = IN15 ' obtain reading from detector
DEBUG dec val05, CR
HIGH cl ' turn off detector
PAUSE 2 ' wait for reset
RETURN
KATH
    edited 2000-04-30 16:35
    Hi Kath,
    If I understand what you are saying, it sounds like the Stamp is resetting
    itself. This is often for several reasons:
    1) If your battery (or other supply) is marginal, turning on something that
    requires a bit of power will reset the Stamp.
    2) Noise can enter on the RESET or ATN line, although this is usually
    associated with motors. I don't think an IR sensor is that noisy.
    3) Falling into a return without a GOSUB (doesn't seem to be your problem).
    I don't know how using SEROUT/SERIN on pin 16 (the programming port) could
    affect pin 15 -- never heard of anything like that happening.
    Are you powering of a battery or the mains? When your program worked before,
    did you not have a serial cable connected (or a shorter serial cable)? Noise
    pickup on ATN increases with a longer cable or a disconnected cable.
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any processor at
    http://www.al-williams.com/awce/pak1.htm
    > From: Kath [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tpLCcpCf64jZqB1t_YktpRox5A-XDjdMHWE2D6BnX0BjNA-r96mZy_D0XO_6yCqZ_y6KGttjSVipexXif8IqnYXDvw]kath@i...[/url
    > Sent: Sunday, April 30, 2000 3:35 AM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Sharp GP2D05 PIR Help! Stamp code keeps looping!
    > Hi All,
    > FOR i = 1 TO 100
    > NEXT
    > ' subroutine read05
    > ' (data line).
    > read05:
    > DEBUG dec val05, CR
    > RETURN
    > KATH
    edited 2000-04-30 18:36
    I'm assuming she is using the STAMPW terminal which takes care of this
    automatically. Also, many carrier boards (like our CAR-I) use a capacitor to
    allow a single reset pulse through. You can find the hookup for that in the
    Stamp manual.
    Al Williams
    AWC
    * Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
    > From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LIW3CmBcwyxmL_igoU5Ar8N7tpruqn12KUuiC6WggTxtwzthXnjnnqxeICDXhRbzpTPr9Ucj]dlc@v...[/url
    > Sent: Sunday, April 30, 2000 12:39 PM
    > Subject: Re: [noparse][[/noparse]basicstamps] Sharp GP2D05 PIR Help! Stamp code keeps
    > looping!
    > Kath,
    > Carefully read the serial I/O section dealing with using port 16. The
    > ATN line will be toggled by the computer which resets the Stamp II. I
    > suggest that you find and put a switch on the ATN (of the Stamp) line
    > if you are going to keep using the port 16 serial I/O.
    > DLC
    > Kath wrote:
    > > Hi All,
    > > FOR i = 1 TO 100
    > > NEXT
    > > ' subroutine read05
    > > ' (data line).
    > > read05:
    > > DEBUG dec val05, CR
    > > RETURN
    > > KATH
    > Dennis Clark http://www.verinet.com/~dlc
    > dlc@v...
    Kath,
    DLC
    Kath wrote:
    > Hi All,
    > FOR i = 1 TO 100
    > NEXT
    > ' subroutine read05
    > ' (data line).
    > read05:
    > DEBUG dec val05, CR
    > RETURN
    > KATH
    dlc@v...
