RF Help
I am working on a project that is using a Transmitter. And what is
happening is the stamp is being effected by the RF from the radio.
I'm assuming it's the inputs that is seeing the RF from the radio. Is
there any way to protect the inputs from the RF from the radio???
Mine is connected to a 1000 W RF transmitter with no problems. Even to a
section detecting forward and reflected power. Would make suggestions of
using bypass caps, ferrite beads, low pass filters and metal shielded
enclosures. Also, try an inductor (RF choke) on the power leads to the amp
and stamp depending on what you are doing. Take a look at the Radio
Amateurs Handbook if you have one available.
Possibly someone has a more direct response for you [noparse]:)[/noparse]
David
To: <basicstamps@egroups.com>
Sent: Sunday, April 23, 2000 7:00 AM
Subject: [noparse][[/noparse]basicstamps] RF Help
>1. Is the power for the stamp and the tX from the same source
2. What is the frequency and power of the transmitter
3. What modulation type is the transmitter
4. what inputs/outputs go to the transmitter
Answer these questions an I can provide a solution to your problem
Norm N8RGR
and even the flouresent lamps & computer trash. Installing 10K pullup or
pulldown resistors cured my problems. Any pin floating will give you
trouble. ==Mac== AG5F
I have had the power set up both ways, connected with the same power supply
and
the radio and stamp with it's own supply. The results are the same.
Frequency using here is 144.100 mhz
FM
4. What inputs/outputs go to the transmitter
What I have set up is Pins 12-15 are set for outputs
Output 15 turns on a 5 volt relay via a transistor Does nothings
but turns on/off a LED.
Output 14 turns on a 5 volt relay via a transistor that keys up
the radio and Pin 7 sends out a DTMF tone When radio is keyed up.
Pins 8-11 are set for inputs. What I have noticed is that when the radio is
keyed up via output 14 that the inputs voltage on pins 8-11 will drop to
about 2.5 volts which will trigger a false input to the inputs pins 8-11.
If I disable the transmitter and run the code again the relay at output 14
will
toggle as before and the inputs 8-11 will be stable, voltage at pins 8-11
will
be 5.02 volts.
I am using the CM8880 Decoder chip circuit also which uses pins 0-6.
The decoder is listening for tones from the radio also.
I have moved the transmitter to different locations and also remoted the
antenna
away from the circuit. The problem still occurs.
The inputs must be very sensitive to RF.
Hope this will help you to help me.
If there's anything else let me know...
Gene
Sent: Sunday, April 23, 2000 11:11 AM
Subject: Re: [noparse][[/noparse]basicstamps] RF Help
> Norm N8RGR
What is it you are trying to transmit? I am thinking about integrating a
transmitter into my basic stamp project for serial data feedback with the
debug command. Just curious to know if yours in a similar application.
~Jim
>I've had a bunch of problems with using power mfets and even a pic with RF
resistor. But still have the problem.
Sent: Sunday, April 23, 2000 6:39 PM
And I'm transmitting a DTMF out of pin 7.
Sent: Monday, April 24, 2000 11:20 AM
> I'm a little curious to know what frequency transmitter you are using.
> ~Jim
RF
same problem when pin 7 is disconnected and you transmit.
Gene Shults wrote:
> Frequency is 144.100 mhz
> From: Jim Szymczak <szymczak@c...>
> > ~Jim
> RF
the transmitter
and the same problem is there. Problem is that the 5 volts on pins 8-11 drop
to about
2.5 volts, which I have pins 8-11 set up for inputs. Which then what happens
is that the stamp
see the 2.5 volts as a input and the input is activated. Freq. operating at
is 144.100 mhz.
I have also tried changing freq. to see if there is any difference, with no
success.
Sent: Monday, April 24, 2000 8:09 PM
> How is the stamp being effected restarting or what, does it have the
integrating a
the
application.
> > > ~Jim
with
> > RF
Is
UHF 10 watt and a 35 watt vhf rig, (446.0 and 146.80), as well as 3
scanners going. (Scanners also transmitt trash). My workbench is appx 4
feet from the transmitters, of course coaxed to outside antennas. The VHF
antenna is no further then 30 ft over my head. I do many hobby projects on
the bench and often transmit while there operating and never had a problem.
Be sure to advise when you find the problem.... ==Mac== AG5F / Owner and
Trustee of W5TNJ rptr.
Someone may have mentioned this already, but if you are not using 8-11 and
these are the ones causing the problem, at the beginning of the code make
them an output and remove your pullup resistors. Then they won't cause you a
problem. Just a thought.
David
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
I am using 8-11 for my alarm inputs.
This project is going to be a alarm system.
Inputs are going to be contacts on doors and windows.
I have my two way radios interfaced into this to alert me when the inputs
are
activated and ableing me to turn the system on and off.
But with the RF causing this problem, the inputs are not stable.
When the two way radio located at the stamp transmits
it's causing the inputs to drop out, causing alarms on the inputs..
Sent: Friday, April 28, 2000 7:17 PM
> Gene,
a
> David
your logic on your inputs and make an intrusion send a HI signal to your
stamp.
Let me try that and I'll get back with you on the results..
Gene
Sent: Sunday, April 30, 2000 10:54 AM
> Can you change your code and use pull down resistors on 8-11, then reverse
> stamp.
