Static Ram Source
Hi, I am looking for a place to buy a 512 - 4 meg SRAM. 1 meg preferred. I
have already tried mouser and digi key only to find that my order has been
permanently back ordered. I would like it to be dip so I can breadboard with
it. It seems like these are fading out of existence but my use is not.
Does any one know of a place where I can purchase a 1 meg dip SRAM that has
it in stock?
btw the mouser parts were less than $3.00 so any suggestions would be nice
if there were within that range.
it in stock?
I need something 256k-1meg 300ns or less is acceptable.
DIP is also preffered.
I have also tried mouser and digikey with no luck.
Ryan
I
with
has
> it in stock?
> Thanks,
>I am also looking for an SRAM chip...
>Ryan
>I
>with
>has
>> it in stock?
>> Thanks,
Gents:
You haven't given all that much information in the way of exacting
specifications,
but I would expect Jameco might have what your seeking. Did either of you
expect
such a device to be Stamp compatable, or is this an OT request ?
Bruce
with a stamp...well if a stamp had more I/O and memory :-)
MP3 player actualy .. I need it for the buffer
> specifications,
> expect
> Regards,
> Bruce
>Its for a PIC project .. picbasic pro... so I am sure It could be done
Hummm Ole Ryan-
Runnin' me around in a circle again <g>.
Let me say this differently - what are the specifications, or what chip
was used in the sample/example or instructions ?
The kind of information required is:
Access -
parallal (multi-pin data) or
serial (single pin data),
and if single pin data what access method
SPI,
Microwire,
I2C, or what
If I offer a chip which doesn't meet the needs of your program, you'll have
to
change the program. If that's okay - fine - the answer is proably Jameco.
They
have all sorts of DIP SRAM. If you want to be more specific, I've got scads of
references and links, as well as datasheets, etc. I *WAS* just trying to save
us some time at MIDNITE last night ... hummm <sun's up already, g>.
Lemme know
Bruce
>> specifications,
>> expect
>> Regards,
>> Bruce
or digi key had. It is for a stamp produt but it will eventually be ported
to a pic once it works so i need decent specs <100 ns seek, etc.
Maybe on another thought i am trying to share a 16 bit bus with a ide hard
drive ram and some other periphials. I thought it would work because only 1
device uses the bus at once and is in hiz the rest of the time. I tried it
with a 2k sram i had laying around and returns mostly garbage. Only a few
bytes get through undisturbed, using the hard drive or not. But connect it
directly it works fine. The only explanation i had was the 15 inch ide
cable was acting like an antenna.
How do i get it to source and sink more? The hard drive works fine and that
is connected to the cable.
To: <basicstamps@egroups.com>
Sent: Saturday, April 22, 2000 1:56 AM
Subject: Re: [noparse][[/noparse]basicstamps] Static Ram Source
> At 12:19 AM 4/22/00 -0400, Ryan Pogge promulgated:
> >Ryan
preferred.
> >I
been
> >with
> >has
> >> it in stock?
> >> Thanks,
nice
> Gents:
> specifications,
> expect
> Regards,
> Bruce
and temp space to decode fat32. That is why im looking for a parallel and
because this is a prototype I would like to use dip to use in my breadboard.
The minimum transfer rate I can have is about 25 KB/s which is like 200,000
baud in serial so that may not be an option. I can read data from the drive
at about 200 KB/s and using this bandwidth would be helpful.
Sent: Saturday, April 22, 2000 2:06 AM
> > specifications,
you
> > expect
> > Regards,
> > Bruce
>I tried jameco and they have a 512K for $13, not even close to what mouser
A shared bus is an animal, all unto itself. There are timing and connectivity
issues, along with buffering, etc. If you're looking for that kind of
processor,
you're into Intel, Zilog, Motorola, etc with ancillary peripheral abilities.
I haven't looked recently at the Scenix site, but I'd kinda doubt they have an
IDE (ATA) driver peripheral - yet. It's certainly worth a look [noparse][[/noparse]
www.scenix.com ]
and head for the virtual peripheral (VP) library.
Have fun with it though !
Bruce
>Thanks
>Mike
>From: "Bruce Bates" <bvbates@i...>
>> >Ryan
>preferred.
>> >I
>been
>> >with
>> >has
>> >> it in stock?
>> >> Thanks,
>nice
>> Gents:
>> specifications,
>> expect
>> Regards,
>> Bruce
yep parallel, again 16 bit bus...
have
> to
> change the program.
hey I can do that.!
Ryan
ported
1
it
hmm I didnt have that problem... I cut an ide cable down to about 4 inches
for mine...
try that , although i doubt thats what is causeing it.
that
u think that would work?
"You think thats air your breathing now?"
> At 09:49 AM 4/22/00 -0400, Michael Licitra promulgated:
mouser
ported
hard
connectivity
> processor,
abilities.
have an
> www.scenix.com ]
> Bruce
it
few
it
that
> >Thanks
> >Mike
> >> >Ryan
> >preferred.
> >> >I
has
> >been
breadboard
> >> >with
not.
that
> >> >has
> >> >> it in stock?
> >> >> Thanks,
be
> >nice
> >> Gents:
> >> specifications,
you
> >> expect
> >> Regards,
> >> Bruce
is, or a pin out?
Sent: Sunday, April 23, 2000 1:51 AM
> how about just useing an old 30 pin SIMM?
> mouser
> ported
> hard
> connectivity
> > processor,
> abilities.
> have an
> > www.scenix.com ]
> > Bruce
tried
> it
> few
> it
> that
> > >Thanks
> > >Mike
> > >> >Ryan
> > >preferred.
> > >> >I
> has
> > >been
> breadboard
> > >> >with
> not.
> that
> > >> >has
> > >> >> it in stock?
> > >> >> Thanks,
> be
> > >nice
> > >> Gents:
> > >> specifications,
> you
> > >> expect
> > >> Regards,
> > >> Bruce
algorithms to the best of my knowledge.
Al Williams
AWC
*Connect a PS/2 keyboard to your Stamp, PIC, SX, or other microcontroller
project: http://www.al-williams.com/awce/pak6.htm
> From: Michael Licitra [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iLjr6vwGEyjJP3Vf-PEXkjyYaMJ1ORc1QrsR_Wig9S6bChEgAZwW7V3jy7fuwJcDJ0caDDcBwOc]mikel2@b...[/url
> Sent: Sunday, April 23, 2000 9:39 AM
> To: basicstamps@egroups.com
> That is a good idea, I never considered it. Do you know what
> type of ram it
> is, or a pin out?
> Thanks
> From: "Ryan Pogge" <rpogge@1...>
> > mouser
> > ported
> > hard
> > connectivity
> > > processor,
> > abilities.
> > have an
> > > www.scenix.com ]
> > > Bruce
> tried
> > it
> garbage. Only a
> > few
> But connect
> > it
> 15 inch ide
> works fine and
> > that
> > > >Thanks
> > > >Mike
> > > >> >Ryan
> > > >preferred.
> > > >> >I
> that my order
> > has
> > > >been
> > breadboard
> > > >> >with
> but my use is
> > not.
> meg dip SRAM
> > that
> > > >> >has
> > > >> >> it in stock?
> > > >> >> Thanks,
> suggestions would
> > be
> > > >nice
> > > >> Gents:
> > > >> specifications,
> Did either of
> > you
> > > >> expect
> > > >> Regards,
> > > >> Bruce
> That is a good idea, I never considered it. Do you know what type of ram
it
> is, or a pin out?
> Thanks
> > mouser
> > ported
> > hard
> > connectivity
> > > processor,
> > abilities.
> > have an
> > > www.scenix.com ]
> > > Bruce
> tried
> > it
a
> > few
connect
> > it
ide
and
> > that
> > > >Thanks
> > > >Mike
> > > >> >Ryan
> > > >preferred.
> > > >> >I
order
> > has
> > > >been
> > breadboard
> > > >> >with
is
> > not.
SRAM
> > that
> > > >> >has
> > > >> >> it in stock?
> > > >> >> Thanks,
would
> > be
> > > >nice
> > > >> Gents:
> > > >> specifications,
of
> > you
> > > >> expect
> > > >> Regards,
> > > >> Bruce
> Garden variety SIMMs are dynamic RAM and require sophisticated refresh
> Regards,
> Al Williams
> AWC
> > From: Michael Licitra [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uX7-IeF7PwYszNBpbHTCz_i4JOywdChnywBkwXvOp34ioE8h9qSGuK9Mt8J1XXUmTyXYgpaTnY2_]mikel2@b...[/url
> > type of ram it
> > is, or a pin out?
> > Thanks
> > > mouser
be
> > > ported
ide
> > > hard
> > > connectivity
of
> > > > processor,
> > > abilities.
they
> > > have an
> > > > www.scenix.com ]
> > > > Bruce
> > tried
> > > it
> > garbage. Only a
> > > few
> > But connect
> > > it
> > 15 inch ide
> > works fine and
> > > that
> > > > >Thanks
> > > > >Mike
> > > > >> >Ryan
> > > > >preferred.
> > > > >> >I
> > that my order
> > > has
> > > > >been
> > > breadboard
> > > > >> >with
> > but my use is
> > > not.
> > meg dip SRAM
> > > that
> > > > >> >has
> > > > >> >> it in stock?
> > > > >> >> Thanks,
> > suggestions would
> > > be
> > > > >nice
> > > > >> Gents:
exacting
> > > > >> specifications,
> > Did either of
> > > you
> > > > >> expect
> > > > >> Regards,
> > > > >> Bruce
socketed cyrus CY7C199 SRAM chips 256K
YAY!
Ryan
mouser
ported
> >> >Ryan
