12v motor contol
Hi everyone!
I purchased the B2SX and need to know HOW if possible I can implement
DIRECTION and speed control to three 12V motors with the chip.
I read about PWM and the chips are limited because they do not output
a steady pulse. I don't know if this is irrelevant but what can I
build instead of purchasing the motor control boards?
Gary
Gary
http://www.phanderson.com/ordering.html )
I would consider using a few of these controllers along with a L293D or
other H-bridge.
Tim
[noparse][[/noparse]Denver, CO]
To: <basicstamps@egroups.com>
Sent: Thursday, April 20, 2000 11:47 AM
Subject: [noparse][[/noparse]basicstamps] 12V MOTOR CONTOL
> Hi everyone!
> Thanks
> Gary
intervention from the Stamp (other than to set it, of course). Just an
SEROUT command is all you need.
http://www.al-williams.com/awce/pak5.htm
For direction control you need an H-bridge. Depending on the size of your
motors, you can build one with power FETs or buy one ready made.
www.bobblick.com has some interesting material on PWM and H-bridges too.
Al Williams
AWC
* Stamp FAQ at http://www.al-williams.com/wd5gnr/stampfaq.htm
> From: Gary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7hEnc4a-eCGeuHEl9eqJtb_chnjbH9eXpGiqrfGBBQD1p4_p3T3zVRurAvI3SDnFWFtEIHdZDGA2e1tj-k8]gcompanion@h...[/url
> Sent: Thursday, April 20, 2000 12:47 PM
> To: basicstamps@egroups.com
> Hi everyone!
> Thanks
> Gary
are TTL/CMOS pretty much like the Stamp's. You can strap the PAK-V to read
inverted or normal RS232 (just like the Stamp).
RS232 (by the spec) is only good to 50 feet. You might get it to work over a
longer distance, but it is iffy.
I have driven a PAK-V with a PC using a 22K resistor to limit the current.
So you might try putting a line driver at the Stamp side and then using a
22K resistor on the PAK's input. On the other hand, you might want to put a
line receiver on the PAK. Again, though, RS232 is supposed to not work past
50 feet (see http://www.al-williams.com/wd5gnr/stampfaq.htm#s2.21).
Since you can configure the PAK to work with true or inverted serial data,
either way is OK as far as the PAK goes. Then you just have to worry about
your line length. If you have +/- 12V you might look at 1488 and 1489 chips.
A single 5V supply can use a MAX232 or MAX233 (233 is more $$$ but doesn't
require external capacitors).
You might consider using a current loop or a RS485 driver/receiver. The
PAK-V only listens, so there is no need for a receiver on the Stamp or a
transmitter on the PAK.
Don't forget, so long as you don't destroy the part, you can return in
within 21 days if it doesn't work out for you.
Al Williams
AWC
* 8 channels of PWM with a PAK-V: http://www.al-williams.com/awce/pak5.htm
> From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e26CCui5JuNuLy4Nl3VzpPhcGdKzpTfXekJFP0tkZtgmQIrksbUkiaKfFRq9lw5bNM0S1yABT1Oq7itlyAV-9Q]bkatakis@m...[/url
> Sent: Friday, April 21, 2000 1:42 PM
> Subject: Re: [noparse][[/noparse]basicstamps] 12V MOTOR CONTOL
> Is there an appnote on the PAK 5 showing it controlled via
> rs232?,,I'd like
> to have one about 60 ft away from where the bs2 is located, but
> don't want to
> buy another bs2.
> Bill K.
> Al Williams wrote:
> > The PAK-V produces 8 channels of PWM all at the same time and with no
> size of your
> > Regards,
> > Al Williams
> > AWC
> > > From: Gary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4W-hxWrST55fVKOPstBBZb4QaqgMyIMdHw5SiDvzYtYZt_ijrh7R1NlMhIwnrtWvWSq2vjrLIjwagMPJMm0]gcompanion@h...[/url
> > > Hi everyone!
> > > Thanks
> > > Gary
to have one about 60 ft away from where the bs2 is located, but don't want to
buy another bs2.
Bill K.
> Regards,
> Al Williams
> AWC
> > From: Gary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7bpxc00eO7JoWH1UqUEmh9XG1Q4L9-0xec0w2wQu7at7ovjl63w8dri400EpIsT8VNbzUzdG53TG]gcompanion@h...[/url
> > Hi everyone!
> > Thanks
> > Gary
