Object detection in sunlight
Hi All,
I have an outside robot that uses a couple of bs2 and I want to give it
object detection and distance capabilities. There's been a lot of discussion
about how to use IR for object detection. Will IR work outside in the
sunlight. If not what else can I use that is stamp friendly...
Jerry
Jerry
I have used it successfully outside in afternoon sunlight at distances
of about 6 inches or so.
DLC
CGIJERRY@A... wrote:
> Hi All,
> Jerry
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
>Hi All,
What about one of those polaroid sonar modules (perhaps mounted on a
servo)? IR tends to be heavily affected by high ambient light levels.
Duncan
>At 11:11 AM 4/20/00 -0400, you wrote:
>>Hi All,
discussion
Duncan
Just some thots to add to yours -
Making the transducers weatherproof might pose a problem, and I'm not sure
about r/c servos in direct weather. I'm also not sure how those "plastic"
piezo transducers might work outdoors in rain/snow or other such conditions.
If the 'bot is only used during good weather, this is certainly not a
consideration.
Just as a sidenote - sound is effected by temperature and athmospheric
pressure,
and humidity as well (I believe). This may or may not enter ito the design
consideration. From a hobbiest point of view, the effects may be so small
as to
be negligable. This is particularly true in areas with minimal climactic
change.
Just my 2 cents
Bruce
>Duncan
bvbates@i... writes:
Hi Bruce,
This is an all weather bot. Stays outside all the time. All the electronics
so far are in a weather proof box including the gear drive and 2 12v
batteries..You can see a pic at
http://hometown.aol.com/yardbot2000/myhomepage/profile.html
I drove a car the other day that had some type of object sensing at the rear.
It worked great and had a range of about 5 ft. Wonder what that used??
Jerry...
>In a message dated 4/21/00 2:47:25 AM Eastern Daylight Time,
>Hi Bruce,
rear.
>Jerry...
Jerry -
They are generally RF, ultrasonic or modulated IR.
The ones used for "parking" generally use ultrasonics. Those with greater
range are either RF or modulated IR. Some RF are microwave range, others
are not.
It's a fairly new technology - last couple of years.
As far as I know there is no "benchmark" or "standard" per se - or
shoud I say there WASN'T in the last articles I read. I MAY have some
references if you would like me to look, but they will be limited to test
applications, various 3rd party or after-market implementations and/or
sensor related articles; thus NOT Stamp-related per se.
Last I looked, Cadillac (GM), Mercedes-Benz, and one of the Japanese
manufacturers
were "hot" - more than that, I really can't say. Undoubtedly Ford has
something as well, but they may have hitched up with the Japanese
manufacturer - sorry I coan't remember which one.
Most of the sensor related "news" I receive is from the Sensors Magazine
mailing
list. They have a webite [noparse][[/noparse] http://www.sensorsmag.com/ ] - you may want to
take a
look there too. I believe they have a search engine for past articles.
Hope that helps.
Bruce
transducers. How do they work? Are they only digital? Stamp friendly?
-William
To: <basicstamps@egroups.com>
Sent: Friday, April 21, 2000 8:27 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Object detection in sunlight
> Hi Bruce,
electronics
rear.
> Jerry...
