multiple devices serial port
As I get started with the STAMP, I notice that most of the really
cool things to interface with (atomic clock, LCD, etc. etc.) all
must connect to the serial port. Since there's only one port on the
STAMP, how can you use multiple devices attached to it, if it's
even possible? Thanks for the help.
Steve
Steve
In fact some special devices let you use the same pin for both (half duplex,
of course).
The pins are TTL level, so you can do 1 of 2 things:
1) Use a 22K resistor in series with the external RS232 transmitter. This
will allow the Stamp's input protection to absorb the extra voltage safely.
Then on your side you can hope the other device will recognize 0 and +5V
(most will, some won't).
2) Use a level converter. The traditional way to go is a 1488/1489 but these
require +/- 12V supplies. You can also use a MAX232 (see the Stamp Project
of the Month this month at www.al-williams.com/awce/som.htm) or -- for more
money -- a MAX233 which requires no capacitors. These chips just need 5V.
In either case, the Stamp can only do half duplex. Also, careful planning is
required to make sure that the Stamp is listening when the device is talking
since the Stamp has no buffer or interrupts. The SXTech site
(www.sxtech.com) will soon have part 2 of my SX course which has plans for
making an SSIB that provides the Stamp with 2 buffered input channels. I'm
not sure why it isn't up yet, but it should be soon.
Also be aware that port 16 "echoes" everything you send to it automatically.
You can read more about serial I/O at the Stamp FAQ:
www.al-williams.com/wd5gnr/stampfaq.htm.
Good luck,
Al Williams
AWC
* Connect a PS/2 keyboard to your Stamp project:
www.al-williams.com/awce/pak6.htm
> From: stephenb@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e5J5mEqPYx1jEj1KS8XHHNqBjxg_h4WYAtuLKq5PpUMue5W9cS174_IObbUHVC0T1npC_4n7jL_1l9_CrtDNNKg]stephenb@a...[/url
> Sent: Wednesday, April 19, 2000 8:24 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] multiple devices serial port
> Steve
Try programming serial communications using I/O pins of the stamp. The I/O
pins are specified in the serial communications commands when writing a
program, so any and all I/O pins of the stamp will support serial
communication.
John
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Wednesday, April 19, 2000 9:29 AM
>Steve
