Stepper motor — Parallax Forums
Stepper motor
edited 2003-10-15 13:00 in General Discussion
Please help anyone?
I am trying to make the Serial Stepper Controller as shown in page
99 of the Basic Stamp Manual 1.8, but it did not work. I was not able
to program the Microcontroller. Every time I try to load the program
in, error message such as "PIC16Cxx-PGM not found". Is there anyone
knows why? I am greatly appreciated for your help.
Ronald
    edited 2000-05-17 22:06
    I've recently salvaged a pair of OKI Electric stepper motors from an
    ancient dot matrix printer, and i need to know where to connect the
    wires on the motor to use them.
    I'm 90% sure the motor is unipolar, and it has 6 wires comming out
    of it, red, blue, black, green, white and grey, in that order. The
    black, red and white wires connect to the motor through a hole
    slightly above the ones for the green, blue and grey ones.
    I want to use an L293D (a simple H-Bridge) to control the motor so i
    get half steps; I don't really need more than 8 steps in total anyway.
    All i really need to know is where to connect the wires.
    -Chris
    edited 2000-05-17 23:48
    With six wires the motor most likely is unipolar, so an H-Bridge is probably
    not what you'd want to use to drive it (H-Bridges are typically used on
    4-wire bipolar motors). You'll probably want to use a ULN2003A transistor
    array, or else four NPN transistors (a schematic can be found in our
    EDE1200 datasheet at http://www.elabinc.com in the EDExx IC Family section).
    Use an ohmmeter to identify which two wires are the common wires. These
    will be the connection for the motor positive voltage supply. The other
    four will be grounded in turn by the drive transistors.
    -Todd Peterson
    E-Lab Digital Engineering, Inc.
    (816) 257-9954 FAX: (816)257-9945
    edited 2000-05-18 00:09
    You can use the motor in a bipolar configuration even though it sounds like
    they are unipolar motors. A 6 wire unipolar motor has 2 center tapped coils.
    To use them as bipolar units you just use the ends of the coil and ignore
    the center tap. You will normally get greater torque running in bipolar
    mode, but will often have a lower maximum RPM than you would get with
    equally sized motors constructed as bipolar units.
    Just be careful on your current draw. If you measure the resistance of a
    full coil and use Ohm's law with the voltage you are planning on using you
    can find out if the L293D is up to the task.
    Tim
    [noparse][[/noparse]Denver, CO]
    To: <basicstamps@egroups.com>
    Sent: Wednesday, May 17, 2000 3:06 PM
    Subject: [noparse][[/noparse]basicstamps] Stepper Motor
    > -Chris
    edited 2000-09-13 19:20
    i'm not to familiar with stepper motors, however, believe this is what i need for a current project.
    1)· can a stepper motor's position be set with pwm? (yes i think)
    2)· can you determine what position the motor is currently in? (yes i hope)
    3)· can a stepper motor go all the way around an infinite amount of times (yes i hope)
    thanks,
    david
    edited 2000-09-13 21:49
    "Production Technology, Inc." wrote:
    > I'M NOT TO FAMILIAR WITH STEPPER MOTORS, HOWEVER, BELIEVE THIS
    > IS WHAT I NEED FOR A CURRENT PROJECT.1) CAN A STEPPER MOTOR'S
    > POSITION BE SET WITH PWM? (YES I THINK)
    > I might be off here, but PWM is better suited to servo and DC
    > motors, than steppers.
    > 2) CAN YOU DETERMINE WHAT POSITION THE MOTOR IS CURRENTLY IN?
    > (YES I HOPE)
    > You can as long as you count steps and save the count as a
    > variable. Repeatability is often a concern and you may need to
    > play with it a bit to reduce errors.
    > 3) CAN A STEPPER MOTOR GO ALL THE WAY AROUND AN INFINITE
    > AMOUNT OF TIMES (YES I HOPE)
    > It will go around as long as it's receiving stepping pulses.
    > THANKS,DAVID
    edited 2001-04-18 18:14
    I have a stepper motor Sankyo and I already control
    it.
    I use something like this:
    'clockwise rotation
    again:
    dirs=%1111
    outs=%0011
    pause 2
    outs=%0110
    pause 2
    outs=%1100
    pause 2
    outs=%1001
    pause 2
    goto again
    I would like to know if there is other way to program
    the secuence and how to tell the program to go reverse
    the motor.
    thank you
    Alex
    __________________________________________________
    Do You Yahoo!?
    Yahoo! Auctions - buy the things you want at great prices
    http://auctions.yahoo.com/
    edited 2001-04-18 19:01
    >it.
    >'clockwise rotation
    >again:
    >dirs=%1111
    >outs=%0011
    >pause 2
    >outs=%0110
    >pause 2
    >outs=%1100
    >pause 2
    >outs=%1001
    >pause 2
    >goto again
    >the motor.
    >thank you
    >Alex
    First I would swap the "again:" and "dirs%1111" statement to read...
    'clockwise rotation
    dirs=%1111
    again:
    outs=%0011
    pause 2
    outs=%0110
    pause 2
    outs=%1100
    pause 2
    outs=%1001
    pause 2
    goto again
    To reverse direction, simply swap two of your sequences that are
    180 deg out of phase...
    'counter clockwise rotation
    dirs=%1111
    again:
    outs=%1100 '<---Swap
    pause 2
    outs=%0110
    pause 2
    outs=%0011 '<---Swap
    pause 2
    outs=%1001
    pause 2
    goto again
    You may also want to half-step...
    'clockwise rotation half-steps
    dirs=%1111
    again:
    outs=%0001
    pause 2
    outs=%0011
    pause 2
    outs=%0010
    pause 2
    outs=%0110
    pause 2
    outs=%0100
    pause 2
    outs=%1100
    pause 2
    outs=%1000
    pause 2
    outs=%1001
    pause 2
    goto again
    'counter clockwise rotatio half-steps
    dirs=%1111
    again:
    outs=%1000
    pause 2
    outs=%1100
    pause 2
    outs=%0100
    pause 2
    outs=%0110
    pause 2
    outs=%0010
    pause 2
    outs=%0011
    pause 2
    outs=%0001
    pause 2
    outs=%1001
    pause 2
    goto again
    Beau Schwabe IC Mask Designer
    National Semiconductor Network Products Division
    500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
    edited 2001-04-20 01:01
    Have the stamp just give direction input to a UCN5804 chip. Send clock input to the chip from 555 timer.
    Roger
    >>it.
    >>'clockwise rotation
    >>again:
    >>dirs=%1111
    >>outs=%0011
    >>pause 2
    >>outs=%0110
    >>pause 2
    >>outs=%1100
    >>pause 2
    >>outs=%1001
    >>pause 2
    >>goto again
    >>the motor.
    >>thank you
    >>Alex
    >'clockwise rotation
    >dirs=%1111
    >again:
    >outs=%0011
    >pause 2
    >outs=%0110
    >pause 2
    >outs=%1100
    >pause 2
    >outs=%1001
    >pause 2
    >goto again
    >dirs=%1111
    >again:
    >pause 2
    >outs=%0110
    >pause 2
    >pause 2
    >outs=%1001
    >pause 2
    >goto again
    >dirs=%1111
    >again:
    >outs=%0001
    >pause 2
    >outs=%0011
    >pause 2
    >outs=%0010
    >pause 2
    >outs=%0110
    >pause 2
    >outs=%0100
    >pause 2
    >outs=%1100
    >pause 2
    >outs=%1000
    >pause 2
    >outs=%1001
    >pause 2
    >goto again
    >dirs=%1111
    >again:
    >outs=%1000
    >pause 2
    >outs=%1100
    >pause 2
    >outs=%0100
    >pause 2
    >outs=%0110
    >pause 2
    >outs=%0010
    >pause 2
    >outs=%0011
    >pause 2
    >outs=%0001
    >pause 2
    >outs=%1001
    >pause 2
    >goto again
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Roger Edberg
    roger@industrialartist.com
    http://www.industrialartist.com
    also:
    Technical Tree Service
    edited 2001-06-02 09:07
    Hello,
    I was wondering if anyone knew how to connect the transistor driver,
    ULN2803A Darlington Array from parallax to the basic stamp and how to
    connect it to the stepper motors. Any diagrams and source code would be
    great. Thanks in advance
    Travis
    _________________________________________________________________________
    Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
    edited 2001-06-02 23:13
    Travis,
    The ULN2803A has the same pinout as the ULN2003 described in Note 6: A
    Serial Stepper Controller in the Parallax Basic Stamp Manual. If you build
    this circuit, a good addition is to use an extra I/O channel of the ULN2803,
    connected to a Stamp output pin, to turn the motor ON/OFF. The circuit
    shown in the manual leaves the motor constantly ON.
    Dennis
    From: Travis M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E7hNezUo-kj0Nz-2uoAKda9H9uJLBI6Fx9K0M5AhmSuNHnT_S_aNXgnQLyTVW0jq6zWoOHnOLavd7i6OmyQ]travis_m25@h...[/url
    Sent: Saturday, June 02, 2001 1:07 AM
    Subject: [noparse][[/noparse]basicstamps] stepper motor
    Hello,
    Travis
    from the same email address that you subscribed with. Text in the Subject
    edited 2001-06-03 20:42
    At 03:13 PM 6/2/01 -0700, Dennis P. O'Leary wrote:
    >Travis,
    Not quite right but very close: the 2003 has 16 pins and 7 driver stages
    whereas the 2803 is an 18 pin device with 8 driver stages. On the 2003,
    pins 1-7 are inputs 1-7; pins 16-10 are outputs 1-7 (note that the outputs
    line up directly across from the inputs); pin 8 is gnd; pin 9 is the diode
    clamp.
    On the 2803, pins 1-8 are inputs 1-8; pins 18-11 are outputs 1-8 (also
    directly in line with their respective inputs); pin 9 is gnd; pin 10 is the
    diode clamp.
    In other words, the 2803 has 2 extra pins added to the end of the package
    as compared to the 2003.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 17 years of Engineering Innovation (1984 - 2001)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2001-06-04 00:02
    Thanks for the correction, Dwayne. The extra driver channel on the 2803
    could be very useful.
    Dennis
    From: Dwayne Reid [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VuwN81xCMeqAH2RcvTL8elheq74W-OEtmVWIXbNE_156csXkZg9KTrTrcR-ckazUZjgiM4y5HRQi9HkV4zTd_g]dwayner@p...[/url
    Sent: Sunday, June 03, 2001 12:42 PM
    Subject: RE: [noparse][[/noparse]basicstamps] stepper motor
    >Travis,
    ULN2803,
    clamp.
    diode clamp.
    dwayne
    edited 2002-06-09 01:50
    I to have used the 5804 and found 80 rpm was max. When I was in school I put the
    5804 on a scope and tested it, I had a perfect signal. This lead me to believe
    that the motor was maxed out at 80 rpm. Im sure with ramping the motor and more
    advanced electronics it would run faster but that was way past my knowledge. I
    also tried the same motor on the little-stepu and had the same results.
    Do You Yahoo!?
    Sign-up for Video Highlights of 2002 FIFA World Cup
    edited 2002-06-09 02:17
    Thank you for the insight Jim.
    Bruce
    edited 2003-10-14 20:12
    I'm just now getting into the subject of running a stepper motor. I know
    nothing about this except that I need to use the basic stamp along with some
    controller of some sort. For this controller, I have my eye on the ULN2803A
    Darlington Array. Where can I find the pin specifications for this thing (and if
    anybody has a better approach to running a stepper motor, please let me know)
    edited 2003-10-14 20:14
    Our StampWorks books shows how to control a stepper motor through the
    ULN2803 -- and you can find the specs all over the Internet (Google it).
    -- Jon Williams
    -- Dallas Office
    From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xI1sjIynf_CvsMP9yuKERwlJPWCl7HxYwtoQIqapB_FVisNXf331zmmezNPIqF_180XWRw]MP1428@a...[/url
    Sent: Tuesday, October 14, 2003 2:13 PM
    some
    ULN2803A
    (and if
    know)
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-10-14 20:52
    In a message dated 10/14/2003 12:20:18 PM Pacific Daylight Time,
    MP1428@a... writes:
    if
    www.google.com is usually a good source to find pin out diagrams of various
    devices
    http://www.controlord.fr/CONTRIB/uln2803.pdf
    ken
    edited 2003-10-15 01:16
    <snip>
    > The black, red and white wires connect to the motor through a hole
    Hi Chris,
    Sounds like pressed steel housing style steppers.
    These should be about an inch and a half to maybe 2 inch diameter
    with a spot welded flat plate for mounting ?
    If it is one of these pressed can motors, try to google whatever you
    can on the nameplate. Most often I find a site where a guy hacked
    them and he posted the data. Since it seems most of these are custom
    for the printer manufacturer, the actual motor manufacturer does not
    post data for them.
    Here's the bad news. the printer had everything you needed to drive
    them. : (
    and, unless they are listed, the voltage could be pretty much
    anything and again, you can get that from the printer when you check
    the power to the driver chip.
    Since they are free, consider running them at either 5 or 12 volts
    and as Tim said, ohm them to determine the amps at the voltage.
    simplest way to run is in unipolar mode, power to the center tap with
    a properly sized high wattage current limiting resistor.
    then a couple darlingtons on the 4 wires.
    For half or quarter step, you will need to get into the linear range
    of the darlingtons and control them at different levels.
    As Tim mentioned, Bi-Polar is the preferred method to get real
    performance out of them but that requires a pretty sophisticated
    power chopping circuit.
    Have Fun !
    Dave
    edited 2003-10-15 01:57
    know
    with some
    ULN2803A
    thing (and if
    let me know)
    > Mike
    Digi-key, put in ULN2803 and look up a part, then the data sheet.
    alternatly just google ULN2803
    as for the last question, there are some great ways to run a
    stepper. I have some boards, multi layer, dozen+ IC's all surface
    mount. 80 volts, 7 amps, chopper, microstepping, about $150.00 each.
    Couple or 4 MOSFET's $1.25 each plus some related parts, less than
    $5.00 a motor for light motors.
    or a ULN2803 at $0.84 each.
    It's like saying you wanna do some monitoring and controlling and
    lighting some lights, what is a good micro ?
    dave
    (btw, had that on another list, after 3 or 4 replies he finally said
    it was for a nuclear power generation facility MONITORING one of the
    coolant lines)
    " > Actually i have to check the capacitance across pipe.The pipe
    > contains mixture of air bubbles and water and these pipes
    > continously supply water to the nuclear reactor.
    > I dont know about ESR. "
    pretty scarry !
    edited 2003-10-15 05:53
    If you're running a bipolar stepper (and you probably should be) check
    out the Allegro A3967SLB controller chip, and the demo board for it.
    Yes, it is a SMT chip, but worth the hassle of soldering a 0.050 pitch
    chip.
    Dennis
    From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZY9QQAgyoLkfwNaojULeHRwmd5zLZc-KkHF0voiFUsvRKMHAxBKlzL7zt95Wz4jmOTDPcYer7M4]MP1428@a...[/url
    Sent: Tuesday, October 14, 2003 12:13 PM
    some
    ULN2803A
    (and if
    know)
    A pc board (TFS-1)is available to allow you to hook up couple of stepper
    motors. (It has 8 high current outputs for any use.)It also serves as a
    programming board and gives you a serial in and 7 other inputs for sensors,
    etc. It supports all 24 pin stamps. Or, if you want two H-bridges for
    bi-directional control instead of 8 individual outputs you want the (TFS-2).
    http://www.geocities.com/jimforkin2003/
    jim
    From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_O7ijgLc0vWwBlCX92chUn_BibgZSRcyiBeT1hcCXzyVy1XFYRIaJvycPrsd3CopzJzuXkzadcz1ypOO4kRaWDc]doleary@p...[/url
    Sent: Wednesday, October 15, 2003 12:54 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Stepper Motor
    chip.
    Dennis
    From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yOJBK57Qy6PByobB2iKh_9Gb3HGf6gIFK2SObjYcChfMO6APwnFjlPlc7ri3VtFm96yZ1Y0C36A]MP1428@a...[/url
    some
    ULN2803A
    (and if
    know)
