PLease Help
I am in need of quick help. I need to program the stamp II to drive
two 4-coil, unipolar steppers. I've been trying several things but i
am such a beginner at the code that i'm lost. If anyone has any
examples that I could see and follow I would be very thankful. If
anyone would mind giving some time to help me with their services, I
would gladly give my services if you need any multimedia publishing,
web pages, or any amateur video editing. Thanks.
Paul Sagona
Paul Sagona
The only thing you may need to change (that I can think of) would be the
baud rate.
If anyone has any suggestions on how to modify this code to run two motors,
simultaneously, each with a different # of steps and different pause delays
I would like to see them. Thanks.
Directn var byte
Steps var word
i var word
Delay var byte
Dir_cmd var byte
N2400 con 17405
Temp var byte
dirs = %01000011 : outs = %00000001
temp = %00000001 : Directn = "+"
goto Prompt ' Display prompt.
Cmd: serin 16,N2400,[noparse][[/noparse]Dir_cmd,dec Steps,dec Delay]
if Dir_cmd = Directn then Stepit
Temp = Temp^%00000011
Stepit: for i = 1 to Steps
outs = outs^temp
pause Delay
next
Directn = Dir_cmd
Prompt: serout 16,N2400,[noparse][[/noparse]10,13,"step> "]
goto Cmd
Geoff Penna
To: <basicstamps@egroups.com>
Sent: Monday, April 17, 2000 10:27 AM
Subject: [noparse][[/noparse]basicstamps] PLease Help
> Paul Sagona
I believe you'll find a nice technical note in the Stamp1 apps. section that
shows the stepper motor coil phase sequence. I used this info and drove a
FET switch directly from a STAMP 1 to do exactly what you want to do. Just
program a loop to constantly output the sequence from a table stored with
the phase sequence. To speed up or slow down use pause statements, to
reverse direction just output the table in reverse. Switching steppers can
be noisey electrically speaking so you may want to isolate the stamp either
with a IGFET or optical isolator if noise becomes a problem. If I can find
the code I'll send it to you.
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Monday, April 17, 2000 10:28 AM
>Paul Sagona
I am building a robot with the parallax and scenix equipment which
includes a SX28AC/DP and 2 servos. How do I test the servos? The
program that I am running gives a memory access error when I try to
load the program into the robot. I have more details, but I'm not
sure which details you need to answer my question, so please let me
know. I am on the servo calibration part of the project.
thanks
>hi,
>thanks
Fractal -
Is this one of the Parallax Robotic platforms ?
Which firmware platform are you using Parallax Stamp Modules or Scenix
Microprocessors when the error is indicated ? If the Stamp Modules, which one ?
What is the exact text of the error ?
Are you using a carrier board, if so which one ?
Which version of the Editor are you using ?
That should be a start.
Bruce Bates
Yes, it is the SX Tech Bot.
> Scenix Microprocessors when the error is indicated ? If the Stamp
It has the SX28AC/DP as well as the SX-Key/Blitz!. I am using the
Stamp Modules II. (Scenix SX20AC/SS AB9931AA)
Access violation at address 004643AE in module 'SXKEY28L.EXE'. Write
of address 01FB1E6B.
I have an SX Tech Bot. I think they call it a BOE Bot. It has a ping
pong ball for a back wheel with 2 servos attached to 2 larger side
wheels. It has 4 AA batteries that go underneath it as well as a
AC/DC adapter from the wall. There is a serial DB/9 connection to the
SX-Key.
The Byte Craft IDE Version 1.1 Build 5 is where I create a project,
open a C file, and attempt to load the program to the robot.
>Hi,
This group is generally limited to support and discussion of Basic Stamps.
The Website for Stamp products is found at [noparse][[/noparse] http://www.parallainc.com ] .
The Stamps In Class discussion group is found at
[noparse][[/noparse] http://www.egroups.com/stampsinclass ] and an easy way
to subscribe to that group is to visit the Stamps In Class website at
[noparse][[/noparse] http://www.stampsinclass.com ] and punch Discuss / EMail.
As far as I'm aware the SX-Tech 'Bot is often discussed there.
Support by Parallax SX-Team can be found by sending E-Mail as follows:
[noparse][[/noparse] mailto:sxtech@p... ]
the SX-Tech website is at [noparse][[/noparse] www.sxtech.com ] and a FAQ can be found their
regarding programming the Scenix SX chips with the SX-Blitz.
Other than that, perhaps one of the List Members here may use the Byte Craft
IDE platform you are using, and can offer some assistance. I don't, so I'm
sorry I couldn't have been of more help.
Bruce Bates
am having no problem communicating with the MAX7219 via the
synchronous serial method.. THe problem that I am having is that I am
using the MAX7219 to drive a 6.8V/segment LED display. The MAX7219
is made to output 5V or so. I am wondering if there is a buffer or
something that i can use that will take the logic level 5v from the
MAX7219 and give me the current and voltage that I need at the
output. I am nearing the deadline here and I need to get this to work.
J
I am using the 7219 to drive 7-segment displays for 5V. You should be able
to drive the 6.8V units - they will just be a bit dimmer. If they are too
dim you might try gradually decreasing the 10K resistor tied to LSET.
Remember - use a separate power supply for the LEDs. The amount of current
they draw would fry a Stamp.
Sid
multiplex 3-digit display available at DigiKey. That is what I am using.
Sid
inverts the signal.
-- Jon Williams
-- Parallax
In a message dated 4/11/02 11:30:04 AM Central Daylight Time,
jay_mann2000@y... writes:
> I am using the stamp to drive the MAX7219 7 SEGMENT driver chip. I
The MAX only allows for a sourcing of 5V. It's outputs aren't designed for
operation beyond that... Have you used one with success without them....???
J
Newzed@a... wrote: Jay, a little addon. Fairchild has a multiplex 4-digit
display and a
Sid
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
