Filtering IR''s
Alex,
How do you know its working if the 555 is reading 0000? Regardless,
check your connections, you may not be connected to the correct I/O pin.
Your servo motions don't tell us how you've hooked them up. What is your
program? Anyway, recheck your connections from the 555 to the Stamp, and
re-test. All those wires on the BOE board get tough to follow after a
while! I have two BoE-Bots, they are way spiff for this kind of stuff.
If you are intersted in interesting programming for robotics, check out
the BoE-Bot downloads for the "Subsumption Programming" article that I
wrote for the BoE-Bot. It will show many interesting programming
examples to do things you would not normally think possible without
interrupts.
So, carefully go over your connections - if your IRPD is now working,
then you have the connection to the Stamp on the wrong pin.
have fun,
DLC
Alex Burke wrote:
> DLC,
> You were right I ended up haveing to fix the filtering on the recievers.
> That part of it works now, but I tried to run the code to adjust the POT
> that was on the board, and all I get is 0000? Also soon as I hook up the
> power to the board, it goes forward just a tad then it jerks right little by
> little. Why is this? I am so sorry that I keep buging you about all this,
> but you seem to know what you are doing, and figured that you could help.
> Thanks "again" -Alex
> >Alex,
> > Did you do all of the things I said to do last time? If you did,
> >it will work. I have used the IS1U60 and it did. If you, at any
> >time, wired Vdd and Vss backwards, the IR detector is toast, even
> >for a second - they don't live through that - otherwise, if you did
> >all of the steps I outlined the last time you posted your problem,
> >it will work.
> >DLC
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
interrupts.
have fun,
DLC
Alex Burke wrote:
> DLC,
> >Alex,
> >it will work.
> >DLC
dlc@v...
