Screwie IR''s
Chris,
Did what you said to fix the filtering problem on my BOE. But when I go
to adjust the POT it just reads 0000? And the robot itself jags right, and
barely moves forward. No matter what it come in counter with. What could I
be doing wrong this time? I am kinda new to this, so please bare with me
hear. I know about electronics, but robotics, I am new to. I would again
appreciate your help. -Alex
Also, I just saw your message about finding IR's yourself. Look at
Digikey. Some one else told me about this a day or so ago. They have a wide
range of recievers there. I am sure that you will find what you are looking
for. (and there prices are pretty reasonable to, that is a +) Hope you find
what you want.
ajb_robotics@h...
ajb_robotics@y...
>Reply-To: basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] Filtering IR's
>Date: Sat, 15 Apr 2000 01:15:01 -0000
>Alex,
>Though I don't know what your exact problem is, since i never saw the
>first post, this may help:
>I had a very similar problem when trying the exact same circuit in
>the BOE manual. Make sure that the 555 Timer is outputting 38,000 Hz
>to the LEDs, (you test it on pg 50). When I followed the schematic
>on pg 49, and i tried this several times, i only got 3800 Hz, exactly
>10 times lower. If you have the same problem, it can be fixed by
>changing the two 1K resistors in the circuit. Change the 1K between
>the Vdd and the Discharge pin to a 220, and remove the one to the pot
>and just connect it directly.
>Hope this helps, it can't hurt.
>-Chris
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
what you want.
ajb_robotics@h...
ajb_robotics@y...
>Alex,
>-Chris
