Filtering IR''s
DLC,
You were right I ended up haveing to fix the filtering on the recievers.
That part of it works now, but I tried to run the code to adjust the POT
that was on the board, and all I get is 0000? Also soon as I hook up the
power to the board, it goes forward just a tad then it jerks right little by
little. Why is this? I am so sorry that I keep buging you about all this,
but you seem to know what you are doing, and figured that you could help.
Thanks "again" -Alex
>Alex,
> Did you do all of the things I said to do last time? If you did,
>it will work. I have used the IS1U60 and it did. If you, at any
>time, wired Vdd and Vss backwards, the IR detector is toast, even
>for a second - they don't live through that - otherwise, if you did
>all of the steps I outlined the last time you posted your problem,
>it will work.
>DLC
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
>Alex,
>it will work.
>DLC
