Filtering IR''s
Alex,
Though I don't know what your exact problem is, since i never saw the
first post, this may help:
I had a very similar problem when trying the exact same circuit in
the BOE manual. Make sure that the 555 Timer is outputting 38,000 Hz
to the LEDs, (you test it on pg 50). When I followed the schematic
on pg 49, and i tried this several times, i only got 3800 Hz, exactly
10 times lower. If you have the same problem, it can be fixed by
changing the two 1K resistors in the circuit. Change the 1K between
the Vdd and the Discharge pin to a 220, and remove the one to the pot
and just connect it directly.
Hope this helps, it can't hurt.
-Chris
--- In basicstamps@egroups.com, Dennis Clark <dlc@v...> wrote:
> Alex,
> Did you do all of the things I said to do last time? If you did,
> it will work. I have used the IS1U60 and it did. If you, at any
> time, wired Vdd and Vss backwards, the IR detector is toast, even
> for a second - they don't live through that - otherwise, if you did
> all of the steps I outlined the last time you posted your problem,
> it will work.
> DLC
> ajb_robotics@h... wrote:
> > Group,
> > I finally narowed down my problem with my IRODS. Like
mostpeople
> > told me, it was my IR's they were not filtering correctly. I am
using
> > a BSX and board of education. The project that I am "trying" to
do is
> > # 4 in the BOE book. But for some reason my IR's so not pick up
> > correctly like I said last time. I have the Sharp
IS1U621/IS1U621L IR
> > recievers. But I was told that I have a filtering problem with it,
> > how can I fix it? what am I supposed to do? I tried seperating
the IR
> > leds and the Recievers, but it still only picks up very seldom.
What
> > is wrong with it, I followed the schematic exactly? It would be a
> > help "again" if some one could help me out here, I am a little
> > confused. - AJB
> > Alex Burke- ajb_robotics@h...
> > ajb_robotics@y...
> Dennis Clark http://www.verinet.com/~dlc
> dlc@v...
-Chris
> Alex,
> it will work.
> DLC
> > Group,
mostpeople
using
do is
IS1U621/IS1U621L IR
the IR
What
> > confused. - AJB
> > ajb_robotics@y...
> dlc@v...
