Filtering IR''s
Alex,
Did you do all of the things I said to do last time? If you did,
it will work. I have used the IS1U60 and it did. If you, at any
time, wired Vdd and Vss backwards, the IR detector is toast, even
for a second - they don't live through that - otherwise, if you did
all of the steps I outlined the last time you posted your problem,
it will work.
DLC
ajb_robotics@h... wrote:
> Group,
> I finally narowed down my problem with my IRODS. Like mostpeople
> told me, it was my IR's they were not filtering correctly. I am using
> a BSX and board of education. The project that I am "trying" to do is
> # 4 in the BOE book. But for some reason my IR's so not pick up
> correctly like I said last time. I have the Sharp IS1U621/IS1U621L IR
> recievers. But I was told that I have a filtering problem with it,
> how can I fix it? what am I supposed to do? I tried seperating the IR
> leds and the Recievers, but it still only picks up very seldom. What
> is wrong with it, I followed the schematic exactly? It would be a
> help "again" if some one could help me out here, I am a little
> confused. - AJB
> Alex Burke- ajb_robotics@h...
> ajb_robotics@y...
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
it will work.
DLC
> Group,
> confused. - AJB
> ajb_robotics@y...
dlc@v...
