Need help - dodgy error!!
While doing the datalogging section of PBASIC we load in a program
using the template.bas file.
We get an error:
Error: can't malloc any more memory (more_nodes)!
What does this mean?? and how do i get around it??
Here is the code we use:
pause 5
serout S_OUT,T2400,(254,1)
pause 30
main:
low ADC_MPX
gosub adcread
serout 7,t2400,(254,128)
serout 7,t2400,("Sensor 1= ",#data," ")
high ADC_MPX
gosub adcread
serout 7,t2400,(254,192)
serout 7,t2400,("Sensor 2= ",#data," ")
pause 1000
goto main
If you require the other code for the sub-procs etc request and i
will deliver.
Thanks - any help appreciated.
We get an error:
pause 5
pause 30
main:
low ADC_MPX
gosub adcread
high ADC_MPX
gosub adcread
pause 1000
goto main
will deliver.
The above filename xxxxx.bas may well be invoking a Windows based Basic
Compiler,
in lieu of the PBASIC Interpereter. The correct syntax for the PBASIC
Interpreter
is:
STAMPn[noparse][[/noparse].EXE] /m fn.ft DOS Version
fn = file name,
ft = filetype
where: n = 1 or 2 (Version: Stamp I or Stamp II)
m = 1 or 2 represents the serial COMM port to
which the Stamp is physically attached
STAMP2SX[noparse][[/noparse].EXE] (as above) Stamp II-SX Version
STAMPW[noparse][[/noparse].EXE] (usually run alone w/o parameters) Windows 9x/NT Version
>We get an error:
Alternatively this could indicate insufficient memory or file handles in a
Windows based program.
What is the command line being executed, and with which operating system ?
>pause 5
>pause 30
>main:
>low ADC_MPX
>gosub adcread
>high ADC_MPX
>gosub adcread
>pause 1000
>goto main
>will deliver.
It should have nothing to do with the PBASIC code (unless it's an internal
PBASIC Interpreter error - unreported to date, as far as I am aware).
More info <smile> !
Bruce
