transistor switch
I need to actuate a 12v solenoid and control it with the 5v output of
the Stamp.
I have a TIP31c npn transistor and the resistance of the solenoid is
90 ohms.
How do I bias this transistor to act like a switch, switching 12volts
to actuate the solenoid?
Ed Lentz
Elentz@e...
the Stamp.
90 ohms.
Ed Lentz
Elentz@e...
Your 12V solenoid will draw~ 12V/90 ohms, or 133 ma. The TIP31C data sheet
indicates that this transistor will saturate nicely at this collector
current with ~5 ma. base current. If we allow 0.7V for Vbe, You need a base
resistor of (5-0.7)/.005=860 ohms. The standard value of 820 ohms would do
nicely, 1/8 watt or more.
1) ground the emitter.
2) connect the solenoid from collector to +12V.
3) connect the 820 ohm resistor from the stamp pin to base.
4) connect a diode across the solenoid to protect against the inductive
turn-off spike. The diode should be rated for at least 133 ma and at least
12V. The diode should "point" toward +12V.
Ray McArthur.
To: <basicstamps@egroups.com>
Sent: Tuesday, April 04, 2000 8:42 PM
Subject: [noparse][[/noparse]basicstamps] transistor switch
> the Stamp.
> 90 ohms.
> Thanks
> Ed Lentz
> Elentz@e...
http://206.19.206.56/parallel.htm
Look all the way to the bottom and there is a description and picture of
what you want.
Tim
[noparse][[/noparse]Denver, CO]
> From: elentz@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ARmY9P42YUUZDn2B-0Pya73r4aHVbYLMUO43qI_NSiLv4oTZNN-e-U7Gum_4VZWfoPR9HrSyOa7MD5b2EuM8zw]elentz@e...[/url
> Sent: Tuesday, April 04, 2000 6:43 PM
> To: basicstamps@egroups.com
> the Stamp.
> 90 ohms.
> Thanks
> Ed Lentz
> Elentz@e...
another is to use a power mosfet
if all else fails get a $2- $3 radio shack relay that has a coil than
directly runs off low power logic signals
richard
Sent: Tuesday, April 04, 2000 7:42 PM
> the Stamp.
> 90 ohms.
> Thanks
> Ed Lentz
> Elentz@e...
I drew out the circuit because I can remember circuits a whole lot longer
than I can words
even though I didn't ask the question - thanks for taking the time to answer
it
richard
Sent: Tuesday, April 04, 2000 8:40 PM
Subject: Re: [noparse][[/noparse]basicstamps] transistor switch
> Ed:
sheet
base
do
least
> Ray McArthur.
> From: <elentz@e...>
> > the Stamp.
> > 90 ohms.
> > Thanks
> > Ed Lentz
> > Elentz@e...
> At 10:51 AM -0400 4/5/00, Bruce Bates wrote:
> >At 07:54 AM 4/5/00 -0500, dakota promulgated:
> > >One way is to just saturate the transistor like a switch
> >Just to add another option -
> >a solid state relay
> gotta be careful here.
> MOST solid state relays are designed for AC and NEED AC in order to 'turn
off'.
> Most of them will turn ON a DC current but will LATCH in the on state
> regardless of your input signal. (IIRC)
> \ / \ / \ N / \ C / \ S / \ S / \ M / \ / \ /
> Chuck Britton Education is what is left when
> britton@a... you have forgotten everything
> North Carolina School of Science & Math you learned in school.
> (919) 286-3366 x224 Albert Einstein, 1936
Just my .02 here.
I had a similar question a while back. Someone on the list recommended solid
state relays. I purchased four (AQZ102) These are dc relays. They have been
cycled repeatedly for hours without any failure (I've been doing some long term
usability testing to see if they would hold up).
I'll have to look up where I got them and who made them..But would gladly do so
if
you want the information.
Rus
Rus Hardy
"Lucky Devil"
Keeper of the Bucky-n-Thrifty Flame
http://www.bluedestiny.com/Anatomical/Index.shtml
"my mind wanders....I'm just along for the ride"
a solid state relay
>richard
>From: <elentz@e...>
>> the Stamp.
>> 90 ohms.
>> Thanks
>> Ed Lentz
>> Elentz@e...
>a solid state relay
MOST solid state relays are designed for AC and NEED AC in order to 'turn off'.
>>a solid state relay
off'.
Depends upon the unit you purchase.
See above
>> >a solid state relay
'turn off'.
left when
everything
1936
>Just my .02 here.
solid
been
term
do so if
Thanks for the confirmation Rus - I would had to dig my dox out.
Bruce
>Rus
>Rus Hardy
>"Lucky Devil"
about 5 large output mosfets with ttl level gates? (IRL3102 by IRF)How do
you protect the micro? Considering a gate "on" voltage of 2.7vdc and a max
gate voltage of 10vdc, a source voltage of 12vdc, 20 amps and more at
startup, the motor is brushless dc and I'm told there will be a voltage
spike when it shuts down. What if I wanted to pulse the gate current to
achieve speed control. How would I build the h-bridge to change motor
direction and do braking? Is there a way to make it rs-232 controlled?
Bill
> richard
> From: <elentz@e...>
> > the Stamp.
> > 90 ohms.
> > Thanks
> > Ed Lentz
> > Elentz@e...
the internet?
Bill Katakis wrote:
> How would you drive the mosfet? What kind of driver if you wanted to run
> Bill
> > richard
> > From: <elentz@e...>
> > > the Stamp.
> > > 90 ohms.
> > > Thanks
> > > Ed Lentz
> > > Elentz@e...
