OT PCB Milling
Does anyone know of a cheap ( < $500.00 ) PCB milling machine.
One that removes copper with a milling bit and hopefully drills the
pin holes also.
Thanks, Bean.
pin holes also.
Thanks, Bean.
I doubt it. Its just not done that way, you etch the metal off,
I have never heard of anyone milling it off.
DLC
> pin holes also.
> Thanks, Bean.
> eGroups.com Home: http://www.egroups.com/group/basicstamps/
> http://www.egroups.com - Simplifying group communications
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
issue?) that advertises that he will mill your boards -- but he wants to do
it for you. www.pcbmilling.com
There are some restrictions, though. It leaves copper around the traces
(ground plane for free, I suppose). I have not tried this.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any micro at
http://www.al-williams.com/awce/pak1.htm
> From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cm7oMp6T2JbApx1y2STT0EFR8b8XconSJCJXfBUWlh-HLwMlPcowkLSj-NnORyOOlkAyikJ0sQ]dlc@v...[/url
> Sent: Monday, March 27, 2000 5:06 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: OT PCB Milling
> Terry,
> DLC
> > pin holes also.
> > Thanks, Bean.
> dlc@v...
bought it from my former employer and they paid $20,000 for it. LPKF is
the brand, but there are others too.
Stew Benedict
The power in technology lies in getting it to
work the way you do, we can help.
Stew Benedict *** AYS Enterprises *** stewb@e...
home.earthlink.net/~stewb ICQ: 18063833
Phone/Fax: 216-228-3983 Pager: 440-302-6438
On Mon, 27 Mar 2000, Dennis Clark wrote:
> Terry,
> DLC
> > pin holes also.
> > Thanks, Bean.
> dlc@v...
Wow. I guess it is possible for one-off boards, but, it doesn't sound
very cost-effective. How fast is it?
DLC
Stew Benedict wrote:
> Yes it is done, I have one of the machines, but they aren't cheap. I
> Stew Benedict
> > Terry,
> > DLC
> > > pin holes also.
> > > Thanks, Bean.
> > dlc@v...
dlc@v...
The following might be a source for you and you might be able to squeak by
for around $500 bucks if you just buy all the components and put it together
yourself.
Its a minimill from http://www.maxnc.com/page3.html ,pretty dang neat IMHO.
They're also very nice too, but a little busy.
But they're programmable by regular M and G codes, not a full set but pretty
good all the same, for example you can do tool offsets and circular milling.
No, I don't work there, just use one at work, not for PCB's rather aluminum
fastener mfg.
Mark
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Monday, March 27, 2000 1:24 PM
Subject: [noparse][[/noparse]basicstamps] OT PCB Milling
>pin holes also.
>Thanks, Bean.
remove all the excess copper. For them it was cost effective, becasue
they pay $1000 a pop for fast turn on protoypes. They machine fell into
disuse though, because we found that for EMI testing, we really needed the
real board with mask etc. to get a good idea of performance. Also, at the
time the software stunk, hopefully it's improved. I haven't put the
machine to use yet, I've got some other plans for it. I traded it for
some consulting work I did.
Stew
do a 1 ft square board. We have had them do a couple prototype boards for us. I
will try to get in tou.ch with a friend who works there and see if he can get me
a name or part number.
>>> Dennis Clark <dlc@v...> 03/27/00 05:06PM >>>
Terry,
DLC
> pin holes also.
> Thanks, Bean.
dlc@v...
increase.
Thanks to all for the info, Bean.
