Newbie Questions — Parallax Forums
Newbie Questions
edited 2003-11-26 17:13 in General Discussion
Hello,
I just subscribed. I see that the current topics are quite a bit more
advanced than mine. This is for STAMP I.
I just purchased a simple kit to build a small robot with my son (11). The
board design has been proven etc. When I put all the components etc on, and
turn on the power, I know the board has power because of a Power LED. When I
try to hook it up to my PC and download a program, I get a hardware error on
the PC side. On my laptop and desktop. The one thing I notice is that with
my laptop, the power led does not light up at all when then STAMP program
tries to download or in DOS mode. On the desktop, I see the power LED go
through 3 phases of lighting... very dim, dim and mildly bright. In neither
case does it emit the same levels of light that it does when the power is
on.
I did my own soldering and really cannot discount anything except that the
resistors, capacitors, chips etc are in the right place.
I attached the schematic for what it is worth.
Any insights or help is really appreciated.
-r
<<Pica.jpg>>
Roger E. Joys
lucy.com
1634 SW Alder
Portland, OR 97205
Tel: (503) 222-7250 x161
Fax: (503) 295-2510
<mailto:Roger.Joys@l...>
<http://www.lucy.com>
    edited 2000-03-26 17:57
    Roger,
    You do keep the power on when it is attached to the PC right? The
    PC won't power the board. It may look like its powering the board when
    you plug the parallel port cable in, but that is just parasitic power
    that gets leeched through I/O pins. The schematic makes it look like
    a neat little robot design I see.
    Some laptops have problems programming the Stamp I throught the parallel
    port, desktop computers don't seem to have that problem. Can you give
    more details of what you are doing that doesn't seem to work?
    DLC
    Roger Joys wrote:
    > Hello,
    > on.
    > -r
    > <<Pica.jpg>>
    > Roger E. Joys
    > lucy.com
    > 1634 SW Alder
    > Portland, OR 97205
    > Fax: (503) 295-2510
    > -- 20 megs of disk space in your group's Document Vault
    > -- http://www.egroups.com/docvault/basicstamps/?m=1
    > Pica.jpg Type: JPEG Image (image/jpeg)
    > Encoding: base64
    Dennis Clark http://www.verinet.com/~dlc
    dlc@v...
    edited 2000-03-26 22:30
    Thank you for the response. I did not have the power on, but when I tried
    this, I still get the error
    "Error Hardware not found" from STAMP.EXE.
    So now the detailed sequence is ...
    Boot to DOS.
    Start STAMP.EXE
    load known good program using ^L
    run program using ^R
    Get error message "Error Hardware not found"
    I also put a BSAVE in the program and tried to load it using BSLOAD. It just
    gives me a message "ERROR".
    So here are some of my theories:
    1). I trashed the STAMP chip when soldering it in.
    2). I miswired something.
    3). There is some oddity about my parallel port that precludes STAMP.EXE
    from using it. I am not sure if it requires a specific IO Address and IRQ to
    function or if it uses LPT1.)
    Thanks all again.
    -r
    From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=17R9BwpjtBRIVlyP_Z_sDfua48bXm6QzCsC961ihUIEaKXD81qzI-VSzb8e29XqE_zoMJy4]dlc@v...[/url
    Sent: Sunday, March 26, 2000 8:57 AM
    To: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Re: Newbie Questions
    Roger,
    DLC
    Roger Joys wrote:
    > Hello,
    and
    I
    on
    neither
    > on.
    > -r
    > <<Pica.jpg>>
    > Roger E. Joys
    > lucy.com
    > 1634 SW Alder
    > Portland, OR 97205
    > Fax: (503) 295-2510
    > Encoding: base64
    dlc@v...
    eGroups.com home: http://www.egroups.com/group/basicstamps
    http://www.egroups.com - Simplifying group communications
    edited 2000-03-26 23:15
    Roger,
    > Boot to DOS.
    > Start STAMP.EXE
    Its a good idea to already have the power on before plugging in
    the Stamp programming cable. BTW, are you sure you have the programming
    cable plugged in correctly? There is usually a >> on the board and the
    cable denoting the ground, you match these, cable to board.
    BSAVE is something else, not part of this issue. Make sure your battery
    is good,
    low batteries will often cause weird problems. Make sure you have +5V
    at the
    correct places on the board, you may have put the regulator in
    backwards. Hmm,
    the schematic doesn't show where +5V is created, where do you get +5V?
    They are pretty tough, you'd have to really botched this to smoke one.
    Make sure they are in correctly though. Pin one is the lower left pin
    on the side of the IC with the notch on it. This is the square hole on
    the PC board.
    Check all your solder connections - especially if you aren't using a good
    quality soldering iron (Radio Shack does not qualify as good quality.) Make
    sure all your connections "cone" with the wide part of the cone at the PC
    board. Round blobs often signify cold solder joints, they won't work well.
    Possible, but not likely, I have used computers brand new to 6 years old
    and they still worked. Only some laptops don't seem to work. Then again,
    I have an old Toshiba 4400 that works fine to program Stamp I's.
    good luck,
    DLC
    > Thanks all again.
    > -r
    > From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Xc_11bNVJ_iHHvXDa40efnIpUouyxl5LRAq2Ef_ZHlFT-kTSwzII3MmVwCY-us3tPIpfAItr]dlc@v...[/url
    > Roger,
    > DLC
    > Roger Joys wrote:
    > > Hello,
    > and
    > I
    > on
    > neither
    > > on.
    > > -r
    > > <<Pica.jpg>>
    > > Roger E. Joys
    > > lucy.com
    > > 1634 SW Alder
    > > Portland, OR 97205
    > > Fax: (503) 295-2510
    > > Encoding: base64
    > dlc@v...
    dlc@v...
    edited 2000-03-26 23:17
    The LPT is standard 378/IRq7 ..
    Power comes from 4 AA batteries. The run through the on/off switch. The LED
    marked LEDP is the one I mentioned that lights up with power. I got 4 fresh
    ones for this project.
    I'll check my solder connections before I post anything more.
    -r
    PS Thanks all
    From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=p520fWiPCGOxzCnSkOXHqEnvnNz6Ih4N1I0Z4y_Os2tM9ML7i-qKaKrV929ndiir0-j3IvqpLKA]dlc@v...[/url
    Sent: Sunday, March 26, 2000 2:16 PM
    Roger,
    > Boot to DOS.
    > Start STAMP.EXE
    just
    is good,
    at the
    backwards. Hmm,
    the PC board.
    to
    good luck,
    DLC
    > Thanks all again.
    > -r
    > Roger,
    > DLC
    > Roger Joys wrote:
    > > Hello,
    The
    > and
    When
    > I
    error
    > on
    with
    program
    go
    > neither
    is
    > > on.
    the
    > > -r
    > > <<Pica.jpg>>
    > > Roger E. Joys
    > > lucy.com
    > > 1634 SW Alder
    > > Portland, OR 97205
    > > Fax: (503) 295-2510
    > > Encoding: base64
    > dlc@v...
    dlc@v...
    -- Check out your group's private Chat room
    -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    edited 2000-03-27 00:49
    That could be it. You may not be supplying the on board regulator with
    enough voltage. A better voltage would be ~7v into the regulator.
    Duncan
    edited 2000-03-27 01:42
    Dennis is right. The schematic doesn't show a 5V regulator. Normally
    Stamps run off 5V supplied from a 3 terminal regulator. I don't know what a
    Stamp will do running off 4 cells. Fresh cells will output up to 6.4 volts.
    Also don't know what the computer port will do with that logic level.
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Sunday, March 26, 2000 5:17 PM
    LED
    fresh
    > -r
    > PS Thanks all
    > From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o6wwbGDbVasGUxZmUjhCw9MpHFDZ8gDveUabPz_crbeBninRBdE6OW-eFNMMJihK9x7FURU]dlc@v...[/url
    > Roger,
    tried
    > > Boot to DOS.
    > > Start STAMP.EXE
    > just
    > is good,
    > at the
    > backwards. Hmm,
    > the PC board.
    good
    Make
    well.
    IRQ
    > to
    > good luck,
    > DLC
    > > Thanks all again.
    > > -r
    > > Roger,
    parallel
    > > DLC
    > > Roger Joys wrote:
    > > > Hello,
    > The
    on,
    > > and
    > When
    > > I
    > error
    > > on
    > with
    > program
    > go
    > > neither
    > is
    > > > on.
    > the
    > > > -r
    > > > <<Pica.jpg>>
    > > > Roger E. Joys
    > > > lucy.com
    > > > 1634 SW Alder
    > > > Portland, OR 97205
    > > > Fax: (503) 295-2510
    > > > Encoding: base64
    > > dlc@v...
    > dlc@v...
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
    edited 2000-03-27 01:55
    You can change the address of your parallel port by entering the bios setup when
    your pc is booting. Check to make sure it is using standard address, don't know
    if the stamp cares but its a shot.
    > Boot to DOS.
    > Start STAMP.EXE
    > Thanks all again.
    > -r
    > From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zPE5ozcCRaxDbQhJgjerKuzerIFfBS-nkbEG8x9ehZwS0pGBptpG9-D_s2qKPrTWdTFjPBzIsQ0hZQ]dlc@v...[/url
    > Roger,
    > DLC
    > Roger Joys wrote:
    > > Hello,
    > and
    > I
    > on
    > neither
    > > on.
    > > -r
    > > <<Pica.jpg>>
    > > Roger E. Joys
    > > lucy.com
    > > 1634 SW Alder
    > > Portland, OR 97205
    > > Fax: (503) 295-2510
    > > Encoding: base64
    > dlc@v...
    edited 2000-03-27 03:13
    Roger,
    Who makes this kit? Maybe we can get some info from them. The schemo
    does not show a regulator, and it shows the servos running off of the
    same +5V as the PIC(Stamp). This may be unwise...
    I checked out the specs for the PIC16C65 (Stamp I) and it says it will
    run on 3.5 to 7.5V, so that shouldn't be the problem. I'm not sure what
    it could
    be at this point.
    DLC
    > Ray McArthur
    > From: Roger Joys <Roger.Joys@l...>
    > LED
    > fresh
    > > -r
    > > PS Thanks all
    > > From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Yl9A37vUSSZBEZ9GPo_8FACVccwwwhraHo1OsGt-NRlk-R9POnRNj3LjhRffIAebwRNfC2E]dlc@v...[/url
    > > Roger,
    > tried
    > > > Boot to DOS.
    > > > Start STAMP.EXE
    > > just
    > > is good,
    > > at the
    > > backwards. Hmm,
    > > the PC board.
    > good
    > Make
    > well.
    > IRQ
    > > to
    > > good luck,
    > > DLC
    > > > Thanks all again.
    > > > -r
    > > > Roger,
    > parallel
    > > > DLC
    > > > Roger Joys wrote:
    > > > > Hello,
    > > The
    > on,
    > > > and
    > > When
    > > > I
    > > error
    > > > on
    > > with
    > > program
    > > go
    > > > neither
    > > is
    > > > > on.
    > > the
    > > > > -r
    > > > > <<Pica.jpg>>
    > > > > Roger E. Joys
    > > > > lucy.com
    > > > > 1634 SW Alder
    > > > > Portland, OR 97205
    > > > > Fax: (503) 295-2510
    > > > > Encoding: base64
    > > > dlc@v...
    > > dlc@v...
    dlc@v...
    edited 2001-10-05 21:15
    I'd like to purchase one of the more powerful stamps with either a
    BOE or the Stampworks kit, but it appears most of the experiments in
    those kits assume you're using a BS2-IC. Is there any reason I
    should steer clear of more powerful stamps (e.g. 2sx and 2p) with
    these kits?
    Which would be a better starter kit; Stampworks or the BOE with the
    SIC experiments? It seems like there is some overlap between these
    two approaches, but they do have differences. Currently I'm leaning
    toward the Stampworks kit, then buying specific SIC experiments which
    interest me and aren't already included in Stampworks.
    Thanks!
    edited 2003-05-09 01:30
    Hello,
    I decided it was time to quit stalling and learn how to use the BS2 I
    purchased awhile back but now I seem to have hit a stumbling block. In the
    following code why does the LED not go out for the five second delay after
    it satisfies the For-Next loop?
    Granted the subroutine is overkill for something as simple as an LED but I'm
    trying to learn to program so please bear with me.
    Tom
    P-Basic program code follows:
    ' File......LED_1.BS2
    ' Purpose...
    ' Author....
    ' E-mail....kf4yyd@a...
    ' Started...
    ' Updated...
    '{$STAMP BS2}
    ' Program Description
    ' Program to learn how to manipulate an LED acting as an output by using a
    ' For-Next loop and a GOSUB subroutine
    ' I/O Definitions
    LED CON 0 'LED connected to P0
    ' Constants
    OUT CON 1 'Designates P0 an output
    DELAY_TIME CON 500 'Pause time in mSec
    ' Variables
    Times VAR NIB 'counter used to hold iteration number
    ' Initialization
    DIR0 = out
    ' Program Code
    Main:
    FOR Times = 1 to 10
    GOSUB Flash
    NEXT
    LOW LED
    PAUSE 5000
    DEBUG "Done!"
    END 'puts stamp in low power mode
    ' Subroutines
    FLASH: 'Turns LED on and off 1x per pass
    HIGH LED
    PAUSE DELAY_TIME
    TOGGLE LED
    PAUSE DELAY_TIME
    DEBUG ?Times 'displays iteration number on debug screen
    RETURN
    edited 2003-05-09 13:44
    Tom,
    Is the other side of your LED connected to the GND or +V rail?
    If you're driving the LED with a low signal it would still flash okay
    because of the TOGGLE command but the LOW LED would keep the LED on for the
    5 seconds.
    Kev/.
    To: "Basicstamps" <basicstamps@yahoogroups.com>
    Sent: Friday, May 09, 2003 1:30 AM
    Subject: [noparse][[/noparse]basicstamps] Newbie Questions
    > Hello,
    I'm
    > Tom
    > ' Purpose...
    > ' Author....
    > ' Started...
    > ' Updated...
    > '{$STAMP BS2}
    > ' I/O Definitions
    > ' Constants
    > ' Variables
    > ' Initialization
    > DIR0 = out
    > ' Program Code
    > Main:
    > FOR Times = 1 to 10
    > GOSUB Flash
    > NEXT
    > LOW LED
    > PAUSE 5000
    > DEBUG "Done!"
    > ' Subroutines
    > HIGH LED
    > PAUSE DELAY_TIME
    > TOGGLE LED
    > PAUSE DELAY_TIME
    > RETURN
    edited 2003-05-10 00:56
    Kev,
    I finally got it straight. The reason it wasn't working is because I was
    using a HIGH when I should have been using a LOW and vice versa.
    Tom
    > From: Kev Pearce (kevp.com) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RnN-_dSIGR4MCb429hFHCAKbmKbgCcepzA313bWVecqeI4WJD57SQE_dGchieBRadNjXcOO4biIB]email.me@k...[/url
    > Sent: Friday, May 09, 2003 8:45 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Newbie Questions
    > Tom,
    > on for the
    > 5 seconds.
    > Kev/.
    edited 2003-11-26 04:10
    I'm just getting started with Robots. I have almost no knowledge of
    electronics. I am familiar with VB and BASIC.
    I have read the book JunkBots, BugBots, and Bots on Wheels.
    Exploring the web I've come across BEAM, Mindstorms,
    Microcontrollers, BASIC Stamps etc.
    I'm not sure where to start. I want to have fun. I'd like to be
    able to get started. I don't want to break the bank (yet). My
    seven year old likes to participate. A short learning curve would be
    helpful.
    I know I'm in a BASIC Stamp group. I'm not sure where else to go.
    How would you guys suggest I get started?
    edited 2003-11-26 15:31
    In a message dated 11/26/2003 10:16:29 AM Eastern Standard Time,
    xer0925@h... writes:
    I would suggest you look at the BoeBot. Go to www.parallax.com and click on
    Robotics.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-11-26 15:34
    I'm sure you will get lots of suggestions.
    The Parallax site has several useful downloads that will help you get
    started. You might also enjoy a few resources that I provide:
    http://www.wd5gnr.com/stampfaq.htm - Basic Stamp FAQ (unofficial)
    http://www.al-williams.com/bs1emu.htm - Free BS1 emulator
    http://www.al-williams.com/som.htm - Project of the month
    There are also several Basic Stamp books out there you can get from Parallax
    or Amazon. I'm partial to mine (Microcontroller Projects with Basic Stamps)
    but I don't think there are any "bad" ones.
    The list is a great resource so that's 90% of the battle. You'll find that
    if you ask very specific questions, you'll get really great answers. People
    are sometimes disappointed when they say something like "I want to build a
    robot," and no one really responds. This is too general. On the other hand,
    something like "I want to build a robotic arm that can throw a pair of dice"
    will elicit a lot of discussion. Even better are questions like "I'm trying
    to drive a motor, and my program keeps restarting." You'll get lots of
    answers to things like that.
    Good luck and have fun.
    Al Williams
    AWC
    * New kits: http://www.al-williams.com/kits.htm
    > From: xer0925 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=32pTUzc2Lq0B2_sAupi5R9gkLTnEfsBE0nfIpAdrtlzZHg8fhug2tT1XVOGBfQbFe9_kYDuZ_ho3EPCgxw]xer0925@h...[/url
    > Sent: Tuesday, November 25, 2003 10:11 PM
    > helpful.
    > Thanks
    edited 2003-11-26 16:10
    check out this web site for a simple robot control:
    http://www.geocities.com/jimforkin2003/
    jim
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qgNRG5esuL3NGKv9DJZ7dOltQzIkfL_Pt2EtEdyho7L5psK-S_O9x5xIbTjkGTVsJhjNsn6al_s]Newzed@a...[/url
    Sent: Wednesday, November 26, 2003 10:31 AM
    Robotics.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-11-26 16:30
    A note of caution to those who uses a JBT's, Darlingtons or even
    Mosfets and that the only connection is a series resistor between the
    Base (or Gate) and the Stamp pin (or driver device).
    It is highly recommended to connect a resistor between the Base (or
    Gate) and Ground.
    The reason?
    If the Stamp goes in a high resistance state and the JBT (Mosfets or
    even more so Darlingtons) is in a high temp enviroment, the leakage
    current Collector to base starts to increase
    (approximately doubles every 10 degrees) and it is possible the
    device starts to conduct and go into a thermal runaway condition.
    edited 2003-11-26 16:39
    One other thing I should have mentioned. Even with a MOSFET, you need a
    reverse diode across the relay coil. You can read more at
    Al Williams
    AWC
    * Real world control for the PC: http://www.al-williams.com/gp3.htm
    > From: Albert Catano [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qK73kbowzUAmclARhyetJNp05IvEUOtHjgfEniQIY7U81hQHL4rxpaweb1Dl1IEYgaL-92kgiMruUgiQvM8p]acatano2002@y...[/url
    > Sent: Wednesday, November 26, 2003 10:30 AM
    > Subject: RE: [noparse][[/noparse]basicstamps] Newbie Questions
    > Gate) and Ground.
    > The reason?
    edited 2003-11-26 16:56
    Unless the switching times are very high, to drive a relay with a
    Mosfet not necessaryly needs an external Diode across the relay coil.
    The reason to use a diode is to clamp the flyback voltage across a
    relay coil is to prevent the exeeding the max ENERGY ratings of the
    switching device (see load line rating of the device).
    The Mosfets has an intrinsic Drain to Source diode.
    edited 2003-11-26 16:58
    Sorry!
    I meant Switching times are very short.
    The tabrobots "SumoBot" has an embedded BS2 on
    board, and a prototyping area. It is controlled
    with an IR remote (supplied). Prices are from
    $50.00 to $90.00. This is probably the least
    expensive price point to getting started.
    With this platform, you can do ALL the
    Parallax 'Analog and Digital Interfacing'
    labs. It is programmed in Parallax PBasic,
    using just a PC and a serial cable.
    A more ambitious 'Bot can be built with the
    Parallax BOE-Bot, but it is more expensive.
    One you get above that, there are LOTS of
    'Bots in the $300 to $500 dollar range.
    The BS2 is a nice module to start with for
    a robot brain -- they are simple, and easy
    to program and debug. Once you get some
    experience, you can try the PIC processors
    the BS2 is based on.
    of
    be
    > helpful.
    > Thanks
