PCB board info
Kerry Barlow wrote:
> I struck out on finding a useable PCboard utility.After testing 10 differant
> PC board programs I found them all to have some deficiency.Mainly the price
> of buying a full package,but also auto routing and ratsnest rewiring etc
> ,there was always some gotcha.
> I wound up using the ExpressPCB program. <SNIP>
I've also used ExpressPCB. With good success.
and after you've prototyped and perfected your board (if you desire to have
professionally made boards), you can send them the file and have boards made at
a
pretty reasonable price.
Rus
a
Rus
I wound up using the ExpressPCB program. I first design my circuit on
paper and then manually route the wires using the program. This appears a
real pain at first but really is not that bad,for low quantities of
components. I so far have done at most 5 IC's and numerous support
components(Resistors,caps,Diodes,plugs etc). I also design all single sided
to save myself grief later on. This of course requires around 3-5 jumpers on
board sometimes.This is no huge problem for home use. To print the board, I
have the program display the board on a white background with black
traces,and the grid turned off. I then do a screen capture of the board with
a differant program and then print the board out to my printer on a
transparency. I use .012 size traces as a minimum.
If you wanted to use the double side feature,then you would eliminate any
unwanted jumpers as well. I use the presensitized boards for PC making.
Right now for example I am making a board for the Homebrew stamp kit. I
have the design finished (single sided) and only 1 jumper wire. I next plan
to add a 555 timer and 5 volt regulator to the board to make it an all in 1
package for my small robots.
This may give people some idea of the level of wiring I am talking about here.
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
the
grid. What program do you use to screen capture? I hate sending a board to be
made
and not testing it first!
Rick
here.
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
imagine any screen capture utility would work. I believe there are others at
www.tucows.com
At 11:23 AM 3/25/2000 -0800, you wrote:
>Hey cool, I have been printing out the pc board and recopying it to get rid
of the
be made
>Rick
here.
>> Sincerely
>> Kerry
>> Admin@M...
>> WWW server hosting
>eGroups.com Home: http://www.egroups.com/group/basicstamps/
Sincerely
Kerry
Admin@M...
WWW server hosting
unbeatable.
DLc
at a
> Rus
> -- Easily schedule meetings and events using the group calendar!
> -- http://www.egroups.com/cal?listname=basicstamps&m=1
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
screen or Alt-Print Screen to capture the active window.
From: rick rowland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JU-QjEzzwj_7PvKFncH_sD7XNbad_AQeIlYIa7PR-QIyU51GdyV4wIH8WpZwx1g4GozzADHYgDS4jH2Rnv0]see3peoh@i...[/url
Sent: Saturday, March 25, 2000 11:23 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Re: PCB board info
of the
be made
Rick
differant
price
sided
on
I
with
plan
1
here.
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
