smoke detector — Parallax Forums
smoke detector
edited 2000-03-24 18:53 in General Discussion
Help.
I want to interface a stamp with an inexpensive smoke detector so that, if
smoke is detected in my workshop, it will activate a relay that will in turn
signal an alarm in the house. [noparse][[/noparse]Note: the stamp is also being used to "alarm"
several other conditions in the workshop.]
My real question is what is the best way to detect the activation of the
smoke detector? My first thought was to open up the smoke detector and tap
directly into it by finding a voltage source that goes "high" when smoke is
detected. But maybe it would make more sense to leave the smoke detector
untouched and "detect" the alarm condition by the sound of the alarm going
off in the workshop. This could then be converted by a (I hope) simple
circuit into an on/off signal suitable for stamp processing. Any ideas
would be appreciated.
HKaresh
    edited 2000-03-23 00:14
    Here is my solution:
    1) Take a 10uF to 47uF 15V capacitor and wire it directly across the two
    battery clips or contact wires of the smoke detector.
    2) Take any of the many 6 pin dip opto isolators and connect the opto input
    so it is in series with one of the battery wires going to the detector.
    The capacitor is required to fool the smoke detector battery sensing
    circuit.
    (The smoke detector IC performs a simulated battery load test every 15 min.
    by drawing current for a millisecond or so and testing the battery voltage
    at the end of this period.)
    3) connect the opto output via a pull-up to the stamp input
    When the buzzer sounds the current goes to 20-40ma and the stamp
    input will go low.
    Karl
    To: <basicstamps@egroups.com>
    Sent: Wednesday, March 22, 2000 2:48 PM
    Subject: [noparse][[/noparse]basicstamps] smoke detector
    > Help.
    turn
    "alarm"
    tap
    is
    > HKaresh
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
    edited 2000-03-23 14:31
    I would probably go with the sound detect. That way the detector is kept
    independent and no need to worry about impairing it's function. Also if you
    need to replace the detector you don't have another project to interface
    again.
    At 07:48 PM 3/22/00 +0000, you wrote:
    >Help.
    > HKaresh
    Larry G. Nelson Sr.
    mailto:L.Nelson@i...
    http://www.ultranet.com/~nr
    edited 2000-03-24 15:04
    Karl - Thank you for your response. I have not used an opto isolator before
    but (from a data sheet I have) it looks like it works like a relay, i. e. if
    the the control current (from the smoke detector circuit) is great enough,
    it will activate the working current that will feed (through a resistor) to
    input a low voltage into the stamp.
    Just to make sure I understand:
    the capacitor across the battery clip - Will this defeat the battery
    checking circuit of the detector (so I need to manually check the battery
    condition occasionally)?
    input to the stamp - I need to initially set stamp input pin high, right?
    >circuit.
    >input will go low.
    >Karl
    >From: "H Karesh" <hkaresh@w...>
    >> Help.
    >turn
    >"alarm"
    >tap
    >is
    >> HKaresh
    >eGroups.com home: http://www.egroups.com/group/basicstamps
    >http://www.egroups.com - Simplifying group communications
    Sent: Friday, March 24, 2000 10:04 AM
    Subject: [noparse][[/noparse]basicstamps] Re: smoke detector
    Close enough,
    The current through the input LED will turn on the LED and the light emitted
    will make the output transistor conduct (like closing a switch)
    This in turn will pull your stamp pin from its high condition to low.
    There is no physical circuit connection between the input and output of an
    Opto-Isolator. I am not too familiar with stamps as I work with 80C31 cpus
    most of the time, but I was under the impression that the stamp inputs are
    pulled high after a power reset. I might be wrong on this. If they are
    pulled igh by the stamp, you wont need the external pullup resistor.
    Karl
    before
    if
    to
    input
    > >circuit.
    min.
    voltage
    > >input will go low.
    > >Karl
    > >> Help.
    if
    > >turn
    > >"alarm"
    the
    > >tap
    smoke
    > >is
    detector
    going
    > >> HKaresh
