The Autopilot using a Stamp
Archiver
Hi all,
Regarding my last message about the Autopilot using light sensors, I
want to be able to build this myself and not get one off the shelf
already made (there's no fun in that), So if anybody knows the best
type of light sensor to use or maybe some sort of weighted pot, How do
you convert these measurements to output pulses to the servos.
Thanks in advance
Thanks in advance
my X-Y solar panel tracking system should be OK for your app.
I would use silicon photocells for the light detection.
They are diodes ( Alltronics.com has some very nice small ones ) and can best be
used by connection to an op amp.. LM324 or ?
The best way to connect them is to put them across the op-amp inputs and use a
resistor
to feedback current.. this current will exactly match the diode /light current
and os you can adjust the sensitivity.
For just a single plane as you describe you'll need 2 diodes set at about 90-120
degrees .
The outputs of the op amps can then goto a ADC (LTC1298 see page 357 of STAMP
manual )and then as digital signals
via a shiftin ( BS2 ) to the BS2. You then can do a simple routine :
flylevel:
if leftlight > rightlight then liftright
liftright:
liftR = out0 ' makes pin 0 same state as liftR
liftR var bit
liftR = 1 ' this will be an output to liftR that you put to a pin0
' pin0 going to 5.0 volts can then move a flap via a servo etc..
you need to loop around this so the sensors keep looking for the
difference. For stable flight you might need to put a PAUSE delay in the
loop otherwise the plane might fly along "wagging" itself...
Date sent: Wed, 22 Mar 2000 00:41:44 -0800
To: basicstamps@eGroups.com
Send reply to: basicstamps@eGroups.com
Subject: [noparse][[/noparse]basicstamps] The Autopilot using a Stamp
> Hi all,
> Thanks in advance
> -- Easily schedule meetings and events using the group calendar!
> -- http://www.egroups.com/cal?listname=basicstamps&m=1
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
directly, without need for an op-amp or ADC. For a tutorial, download--
http://www.stampsinclass.com/downloads/em4.pdf
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
----original message---->
HI I am totally new to Pbasic and STAMPS but the system i am trying to use
for my X-Y solar panel tracking system should be OK for your app.
best be used by connection to an op amp.. LM324 or ?
use a resistor
current and os you can adjust the sensitivity.
90-120 degrees .
STAMP manual )and then as digital signals
flylevel:
liftright:
liftR var bit
> Hi all,
> Thanks in advance
Ronald Doctors
Okay, this should keep you busy for a while...
http://www.euronet.nl/users/ragman/robot1.html
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
STAMP so i needed to
MUX both the A/D in and the control bits out.
Might be good for a RC plane though!
Thanks for pointing the article out.
Date sent: Wed, 22 Mar 2000 12:45:58 -0500
To: "INTERNET:basicstamps@eGroups.com" <basicstamps@eGroups.com>
Subject: [noparse][[/noparse]basicstamps] Re: The Autopilot using a Stamp
> I just wanted to point out that the RCtime command can read photodiodes
> -- Tracy Allen
> use a resistor
> 90-120 degrees .
> flylevel:
> liftright:
> liftR var bit
> From: "Paul" <paul.byrne@b...>
> > Hi all,
> > Thanks in advance
> Ronald Doctors
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
Ronald Doctors
