Analog relative movement sensor
I'd like to monitor the slippage dynamics of a human head-mounted device
during rapid head movements. Slippage is largely due to skin movement
under the head strap, relative to the skull. Ideally, I'd like something
like a Hall-effect device mounted on the slipping head strap, sensing
position of a very small magnet taped to the skin. But these devices
produce digital pulses (not analog distance) when near the magnet. I
would prefer an analog output sensing relative movement of sensor and
reference maker over a small range of 5-10 mm. Any suggestions will be
welcome. I'm still scratching my (slipping) head over this one.
Dennis
Dennis
the manufacturer's name, but I believe that thru a web search you could
easily find it.
ACJacques
> Dennis
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
A wonderful supplier of Hall Effects and information is Allegro
Microsystems.
http://www.allegromicro.com/
Another is the Microswitch company, I don't have their web address.
Look at http://www.plano.com/mfrz.htm for all component manufacturers
web sites.
Jack Wilker
Honeywell and others make them . They are not expensive and very simple to use.
They are a bit power hungry so battery powered systems might be a challenge if
you need
tracking for a long time.
I have some very small magnets about 0.2" x 0.2" x .05 "( Rare earth type )
that could be used.
An alternate method that springs to mind is to use an optical pattern on the
skin and use
moire fringes to detect movement..
Date sent: Mon, 20 Mar 2000 20:25:33 -0300
To: basicstamps@egroups.com
Send reply to: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Analog relative movement sensor
> There are Hall-effect sensors with analog output. I do not remember
> easily find it.
> ACJacques
> > Dennis
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
