Digital to Analog Converter with Stamp
Does anyone know if a Basic Stamp can be used for D to A converter. I
think that it can but have no idea how. If anyone has done this before and
has some information I would like to review this to get me thinking on the
right track. Also what type of stamp needs to be used.
John
John
if you are pulling any load, you'll need a transistor or op amp buffer.
Also, you can't do anything while charging the capacitor.
You can also use a PAK-V for this. Then you get 8 channels of PWM that all
run all the time and the Stamp can do other things.
http://www.al-williams.com/awce/pak5.htm
Al Williams
AWC
* Stamp project of the month at http://www.al-williams.com/awce
> From: JOHN8003@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_-A2VpAbX6iB4AHzn3tI8hT5fkzIFj8-9ppAMzXuUhyU33vGQk12AG6pjO580FDnaWcOMLNZbeY]JOHN8003@a...[/url
> Sent: Friday, March 17, 2000 7:23 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Digital to Analog Converter with Stamp
> before and
> thinking on the
> Thanks
> John
> eGroups.com Home: http://www.egroups.com/group/basicstamps/
> http://www.egroups.com - Simplifying group communications
There is probably an easier way than this but it will work .. ( I think )
assuming you have say a byte of data. Send the data out to a serial in parrallel
out
shift reg and then take each of the 8 outputs via a weighting resistor to the
summing junction of
an op amp. the output will be the analog of the original byte.
A nother way is to use an A/D convertor ( see STAMP app for this ) and
make closed loop with successive approx.
rom: JOHN8003@a...
Date sent: Fri, 17 Mar 2000 20:23:19 EST
Send reply to: basicstamps@egroups.com
> Thanks
> John
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
>D/A should be easy since you just can use a summing amp with integration.
parrallel out
the summing junction of
At this point you could also use an R2R resistor ladder...
2R
D0 >--/\/\--o
< R
2R |
D1 >--/\/\--o
< R
2R |
D2 >--/\/\--o
< R
2R |
D3 >--/\/\--o
< R
2R |
D4 >--/\/\--o
< R
2R |
D5 >--/\/\--o
< R
2R |
D6 >--/\/\--o
< R
2R |
D7 >--/\/\--o----> Analog Output (0-5V)
Note: if R = 1K, then 2R = 2K
...If you could "Spare" the pins, you could use this idea right off of
the Stamp, without the use of a shift register.
>rom: JOHN8003@a...
>> Thanks
>> John
You forgot one 2R resistor to ground for the D/A. (See below)
GND
o
< 2R <--- Add this one
2R |
D0 >--/\/\--o
< R
2R |
D1 >--/\/\--o
< R
etc, etc.
Jared
Electrolinx - http://www.geocities.com/electrolinx/
VB Overdrive - http://extreme-vb.net/vboverdrive/
