Sharp IP detectors, which one?
hello All: I was looking at the sharp IR range detectors for the stamp II
It looks like I can buy a digital output range,or an analog output detector.
Which ones are easier to interface with the stamp from a software standpt?
If I used analog(GP2D12) would the stamps analog input work here?. My
problem is monkeying with a digital string value of range and trying to get
something usefull out of that for my robot when using the GP2D02. I can
understand analog in my mind easier. Also where is a good place to buy these
sensors? I found acroname.com Prices are not to bad there,but another web
author says they can be had for under $10. Acroname wants $21 digital and
$13.50 for the analog version. (Of course the web author is unavailable.)
Thankyou to everyone
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
Sincerely
Kerry
Admin@M...
WWW server hosting
MC33030 chip it has it all built in..I use plain silicon cells from Alltronics
with good success
i mounted 4 of them in a "pyramid" and potted them so they are waterproof in
resin.
the result is a X-Y tracker.
Date sent: Thu, 16 Mar 2000 14:13:25 -0500
To: basicstamps@egroups.com
Send reply to: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Sharp IP detectors, which one?
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
-William
To: <basicstamps@egroups.com>
Sent: Thursday, March 16, 2000 3:28 PM
Subject: [noparse][[/noparse]basicstamps] Re: Sharp IP detectors, which one?
> If you are trying to use the IR for s guidance problem look inot the
MOtorola
Alltronics with good success
in resin.
> From: Kerry Barlow <admin@m...>
II
detector.
standpt?
get
these
web
and
unavailable.)
> > Sincerely
> > Kerry
> > Admin@M...
> > WWW server hosting
> Ronald Doctors
> -- 20 megs of disk space in your group's Document Vault
> -- http://www.egroups.com/docvault/basicstamps/?m=1
. you can look it up via " IC master "
For use with detector diodes it has a built in amp and comparitor, also has full
H bridge
I like it 'cause it's cheap and simple..
Date sent: Thu, 16 Mar 2000 17:14:26 -0500
> ?? What? Is this a IR detector chip?
> -William
> From: Ronald Doctors <rdoctors@h...>
> MOtorola
> in resin.
> II
> detector.
> standpt?
> get
> these
> web
> and
> unavailable.)
> > > Sincerely
> > > Kerry
> > > Admin@M...
> > > WWW server hosting
> > Ronald Doctors
> -- Check out your group's private Chat room
> -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
Ronald Doctors
> II It looks like I can buy a digital output range,or an analog output
> detector. Which ones are easier to interface with the stamp from a
> software standpt? If I used analog(GP2D12) would the stamps analog input
> work here?. My problem is monkeying with a digital string value of range
> and trying to get something usefull out of that for my robot when using
> the GP2D02. I can understand analog in my mind easier. Also where is a
> good place to buy these sensors?
Actually, the GP2D02 (we call our kit the "Digital Infra-Red Range-
finding System" or "DIRRS") is much simper to use on the Stamp.
The DIRRS kit comes with BS2 code that makes it a snap to use.
You could use the GP2D12, but you'd need an external A/D which
is often more trouble than it's worth.
see: http://www.hvwtech.com/robotics.htm#dirrs
for details. You can take advantage of the difference between the
US and Canadian currencies and get an automatic 35% discount
too !
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: +403-730-8603 Fax: +403-730-8903
four at www.acroname.com
-William
Sent: Friday, March 17, 2000 11:46 PM
> too !
> eGroups.com Home: http://www.egroups.com/group/basicstamps/
