Servo Motors
I need to pull a metal pin that is about .500" (1.27cm) in diameter out of a
mating receptacle. The amount of force required for the pull is about 6
linear pounds (2.7 kg).
The issues are the cost and size of the standard servos.
Does anyone have any ideas of what to use that will fit into an
approximately 1.5" ( 3.8 cm) diameter tube?
The required travel distance is about .250" (6.3mm).
Comments on this one Ronald Doctors?
Thanks.
David
Thanks.
David
There's a standard type of linear actuator that uses a stepper motor with a
threaded shaft through the center... And you could do something similar by
using a conventional motor to turn a nut that draws a threaded shaft
through the required stroke. Industrial equipment vendors sell complete
assemblies for jobs like this.
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
Is there any reason for precision positioning? Or are you just wanting to
pull the pin out of a detent or locking hole and then have the ability to
re-insert it? If all you are doing is moving the pin in and out there are
tons of linear actuators out there that should be able to do the job with
simply and on and off command. If you have compressed air available a simple
double action air cylinder and inexpensive electric solenoid air valve would
solve the problem
Hope this helps
Randy A.
mountain!
To: "PIC STAMP LIST" <basicstamps@egroups.com>
Date sent: Wed, 15 Mar 2000 21:24:48 -0800
Send reply to: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Servo Motors
> Thanks.
> David
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
Thanks all for the response.
The linear actuator that uses a stepper motor sounds like a plan but may be
to costly for my little project. I will certainly look into this though!
Yes, the pin will be "re-inserted" by the actuator. This a battery powered
device....low power is the key.
Ronald, Your idea of a motor and gears is interesting too. I worked with
some tiny maxon? motors about 10 years ago. Very powerful. In fact, I used
it in a microwave oven turntable. I captured the microwave energy from
inside the oven using a "rectenna" rectifying it before the motor. Very
slow speed and powerful for the turntable, but the
motor was turning fast.
You've all given me some clues. Thanks!!
David
To: <basicstamps@egroups.com>
Sent: Thursday, March 16, 2000 9:25 AM
Subject: [noparse][[/noparse]basicstamps] Re: Servo Motors
> David,
a
of a
> eGroups.com Home: http://www.egroups.com/group/basicstamps/
degree turn. help
BOE-bot manual (available for down load from the Parallax website. I have
done it with very little difficulty; if I can do it, <<anyone>> can [noparse];)[/noparse]
Good luck.
peter
Peter C. Charles, Ph.D.
Research Assistant Professor
Department of Microbiology and Immunology
Rm. 730 Mary Ellen Jones Building, CB# 7290
UNC
Chapel Hill, NC 27599-7290
"He that but looketh on a plate of ham and eggs to lust after it, hath
already committed breakfast with it in his heart."
--C.S. Lewis
From: gmonrose@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4rRyBzahoOFtWxr-In79xVPWyflfWUyQ3DE6IOuhbMEvTtQSzDFFLjrRNPD4X4eaHyF5W3HNRrW7qy_E]gmonrose@j...[/url
Sent: Saturday, October 07, 2000 9:08 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Servo motors
I want something as precise as a servo but that can make a full 360
degree turn. help
http://www.technologyindex.com/
Sent: Saturday, October 07, 2000 2:08 PM
> degree turn. help
> degree turn. help
Servos can be modified for continuous rotation quite easily. Follow
the link on:
http://www.hvwtech.com/servos.htm
to a photo tutorial on how it's done.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: +403-730-8603 Fax: +403-730-8903
the servo, unless you add some sort of an external feedback.
I've found that you can squeeze close to 180 degrees of rotation
out of a standard hobby servo, without any modification. If this
pan/tilt setup will be mounted against a wall or in a corner, I would
think that you'd do fine with unmodified servos. As always, YMMV.
Cheers,
Steve
<< > I want something as precise as a servo but that can make a full 360
> degree turn. help
the link on: >>
will be ceiling mounted (in the center of the room?). How about
a standard servo for the tilt mechanism, and a cheap stepper
motor for the pan mechanism?
Cheers,
Steve
<< If this pan/tilt setup will be mounted against a wall or in a
corner, I would think that you'd do fine with unmodified servos. >>
>degree turn. help
Assuming that you are not looking for rotation, (as the other posts are),
and are looking rather for precise posisioning within 360 degrees, you
can use a servo with a 4/3 gear ratio to your controlled device or a stepper
motor with some kind of position feedback.
