Static Field Detection
Does anyone know of any type of inexpensive equipment or a basic stamp
solution for measuring any type of ambient static electricity field? I don't
know much about the subject, but I was hoping to have a way to adjust the
sensitivity and have some type of bar graph output or panel meter output.
Any suggestions would be appreciated.
By the way, I'm glad to see that so many people have decided to stick it out
with the move to egroups. This very well might make a great thing even
better.
Thanx in advance,
Kurt G.
______________________________________________________
better.
Thanx in advance,
Kurt G.
Static fields can be measured with a small electrode tied to an FET input
amplifier. A grounded metal chopper wheel rotates between the field you're
measuring and the sensor plate. You amplify the AC output and rectify it to
get static field intensity. There are other methods...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
If you can find a mosfet device that doesn't have any input diodes
it would make a good detector, unfortunately it might not last very long!
The old gold leaf electrometer could be made with aluminum foil and the
seperation measured with a optical system.
A vacuum tube also is great and almost indistructable. A triode with the grid
just left as an antennae will detect low voltage fields, it can also detect high
voltages by
a capacitively driven feedback system. This could be part of an A/D loop that
would give you the
static field. if you only need the gradient then the triode could have a pair of
probes one grounded and the other
to the grid..
Just some ideas...
To: basicstamps@egroups.com
Date sent: Wed, 15 Mar 2000 07:46:34 CST
Send reply to: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Static Field Detection
> better.
> Thanx in advance,
> Kurt G.
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
RIDICULOUSLY SENSITIVE CHARGE DETECTOR
http://www.eskimo.com/~billb/emotor/chargdet.html
> From: "K Gilbert" <busyman1972@h...>
don't
Ciao
Dave Saum
Infiltec
http://www.infiltec.com
