need magnetic sensor
The device you want is called a Hall effect sensor. I know that you can get
them from Mouser or Digikey- Radio Shack might also have them. They are
pretty cheap, if memory serves.
peter
Peter C. Charles, Ph.D.
Research Assistant Professor
Department of Microbiology and Immunology
Rm. 730 Mary Ellen Jones Building, CB# 7290
UNC
Chapel Hill, NC 27599-7290
peter
UNC
are available from ( Jameco. #169691).
The latching ones have no bounce but do need a reverse polarity , that is a N
and sth pole at each location.
It's worth the effort to sue them as they much more relaible than reed switches
and do not break.
To: <basicstamps@egroups.com>
Date sent: Mon, 13 Mar 2000 11:04:25 -0500
Send reply to: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Re: need magnetic sensor
> peter
> UNC
> eGroups.com home: http://www.egroups.com/group/basicstamps
> http://www.egroups.com - Simplifying group communications
ron... the motor man...
Ronald Doctors
http://www.members.home.net/rdoctors
will be much
easier to use for quick pulses they have a fairly high freq. response (how many
times they
can sense in given period)
Ronald Doctors wrote:
> Use the latching type of hall sensors cost about $0.99 each PT number HI400
and are available from ( Jameco. #169691).
switches and do not break.
> From: "Dr. Peter Charles" <pcharles@m...>
> > peter
> > UNC
> Ronald Doctors
