problems when bs2sx is not connected to desktop
Sounds to me like you have a ground problem. Make sure all your grounds are
tied together somewhere.
Just a guess.
Al Williams
AWC
*Read a PS/2 keyboard from your Stamp or other microcontroller project.
http://www.al-williams.com/awce/pak6.htm
> From: Steve Znavor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P-9ZA4p_aX8uF-ksPFrbIK9ooDlN6dqzvSU5DpfSZ96Js7OXdUwi0jgLzxPjIXBdkoVVus-VzPVgr8CPMyHy]sznavor23@h...[/url
> Sent: Sunday, March 12, 2000 9:06 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] problems when bs2sx is not connected to desktop
> When i run my BS2SX program by hitting the "run" icon on the basic stamp
> editor and the debug screen pops up the program runs absolutely
> perfect...but when i turn off power and disconnect my BS2SX from
> my computer
> (its running by itself now) and then power it back up the stamp
> works only
> every now and then barely ever--i dont get it. Is there
> anything i can do
> to fix it?
> ______________________________________________________
Just a guess.
Al Williams
AWC
> my computer
> works only
> anything i can do
> to fix it?
perfect...but when i turn off power and disconnect my BS2SX from my computer
(its running by itself now) and then power it back up the stamp works only
every now and then barely ever--i dont get it. Is there anything i can do
to fix it?
Get Your Private, Free Email at http://www.hotmail.com
For what its worth: I had a stamp running with only a serial lcd attached,
which would run perfectly while attached to the computer. When the cable
was removed from the stamp, the program would not run. Reset and power
up/down had no effect. It turned out that the problem was that I was
driving the display with a desktop power supply, and the stamp with a line
transformer. Apparantly the slightly different grounds caused a problem.
Once I powered the stamp from the desktop power supply it ran
perfectly...cable or no.
>From: "Steve Znavor" <sznavor23@h...>
>Reply-To: basicstamps@egroups.com
>Date: Mon, 13 Mar 2000 03:06:00 GMT
>computer
>to fix it?
>eGroups.com home: http://www.egroups.com/group/basicstamps
>http://www.egroups.com - Simplifying group communications
