Floating button?
Ok, I'm building a two motor walker with
some modified servos. My servos have a pretty bad error in them that I can't
seem to fix, so I've put a switch that tell me when they are centered. It's
basically a wire and a resistor that connect. So, I've wired it up just like
the stamp manual for a button, but I'm using a 470ohm resistor. I'm using
the button command that triggers when high. Just using debug to print the
results, I get a solid 1 when connected, but a fluctuating 1 and 0 when not
connected. Why? Also, if I move my hands shadow across the wires the value
changes. Freaky. Can anybody help?
-William
____________________________
http://robot-central.webjump.com/
Robotics books, projects, resources,
links, news, and more!
-William
"Triple" check your wiring arrangement. It sounds like the stamp pin is
floating.
It will not float if the resistor is connected properly.
David
To: Stamps <basicstamps@egroups.com>
Sent: Saturday, March 11, 2000 2:10 PM
Subject: [noparse][[/noparse]basicstamps] Floating button?
can't
It's
like
not
> -William
> -- Easily schedule meetings and events using the group calendar!
> -- http://www.egroups.com/cal?listname=basicstamps&m=1
10k)
-William
To: <basicstamps@egroups.com>
Sent: Saturday, March 11, 2000 5:17 PM
Subject: [noparse][[/noparse]basicstamps] Re: Floating button?
> William,
> floating.
> David
> From: William Cox <william@c...>
> can't
> It's
> like
using
the
> not
value
> > -William
> -- 20 megs of disk space in your group's Document Vault
> -- http://www.egroups.com/docvault/basicstamps/?m=1
> 10k)
> -William
470 ohms should be fine. this is 10mA at 5 volts. I don't think a 10k
would make a difference.
I don't see why it would float?
Quadruple check the resistor connections and your code.
Does anyone else have any ideas?
David
pin, the value of the resistor could be 4k7 - 20k
hope this helps
JON
that I can't
centered. It's
just like
using
print the
when not
the value
> -William
