Homework Board
BIG problem....· I hook up a battery to my homework board, the green power light flashes and it turns off....· nothing is working...· Tried replacing the battery, unplugging and plugging in the cable.· Dissconnecting EVERYTHING from the project baord.....· any other ideas???
-X
-X
Does the LED still flash when the battery is connected ?
If not then the regulator may be blown.
Terry
So what should I do now?
X
The LED on the homework board does not stay on if it is not running a program like it does with the Board of Education.
Run your Basic Stamp Editor program with the battery connected to the Homework board and the Homework board connected to the Serial port. Then click on the ID "identify" button in the Basic Stamp Editor. If your stamp shows up on one of the com ports then it is working fine.
Let me know what you discover,
Luke
And no, the computer is not finding the board...
Thanks though,
X
You are in a maze of twisty passages...all alike...
Here's a link to the manual:
http://www.parallax.com/dl/docs/prod/boards/hwb.pdf
Page 4 explains why the power LED turns off when no program is running or it reaches an END command in the program.
Sounds like you might have another problem and should try parallax technical support.
now what??? :-/
-X
The others did a pretty good job troubleshooting it for you. I recommend using a new battery and trying again. If you still can't identify the Stamp from the editor (and you used to be able to) then you could have damaged something. It's not a problem, though.
Call us Monday morning for an RMA number for a repair. Our Sales Manager Jim Carey will be in the office by 7:00 a.m. PST.
