Serout Not Working when Debug disconnected
I have my BS2pe stamp hooked up on a board where the 4 programing pins (1,2,3,4) are hooked up for programming the stamp. I am also using two I/O pins for the SEROUT and SERIN commands that send messages to another computer running VB. I thus have two serial cables hooked up. When I download my program into the stamp, things run nicely and I get debug statements into my computer and I also get messages from the SEROUT command which goes to another computer which is running a VB program that reads the incoming messages from the SEROUT.
My frustrating problem is this:· When I remove the serial cable from the DB9 connector that connects to the 4 programming pins, the SEROUT commands appear to stop working since my VB program does not get any messages from the stamp . The minute I plug the the stamp·programming cable·back in, the·serout starts working again. What gives???·This problem seems fundamental but I can't figure it out. Do I need to disconnect the ATN pin? ·Any help would be greatly appreciated.
Thanks in advance,
Eric
Thanks in advance,
Eric
on MSCOMM, check property DTREnable and toggle it.
That's all ok
