How to do digital to analogue conversion using LTC1257 ?
Dear all,
Hi!
I have a Digital to Analogue Converter IC (LTC1257).
May I know how to use my Basic Stamp 2(BS2) to convert the digital signal to analogue signal?
Thank you.
Best regards.
Kam
Thank you.
Warm regards.
Kam
Hi!
Thank you.
Best regards.
Kam
Thank you.
Warm regards.
Kam
Jon Williams
Dallas Office
I have some problem on my BS2 code:
1.When I did SYNTAX CHECK, an error "Out of variable
space" happen at "Y"
Why ? just only five WORDs declare only, the error
already come out ?
I have remark the code.
2.Refer to Jon's URL link for the DAC PDF file,the DPin in my BS2 code under DAC section is refer to Pin 2(Din) on the LTC1257 ? and the DAC in the code is refer to Pin 3(LOAD) on the LTC1257 ?
Clk··· PIN·· 0
Dpin·· PIN·· 1
DAC··· PIN·· 5
temp··· VAR··· Word
tempL·· VAR··· temp.BYTE0
tempH·· VAR··· temp.BYTE1
dac1··· VAR··· Word
dac2··· VAR··· Word
shift·· VAR··· Byte
Attach here is the program BS2 code.
Thank you.
Best regards.
Thank you.
Warm regards.
Kam
