BS1 shifting
for the BS1,
i know its not the prettiest thing in the world but it works.
but if anyone has any ideas on how to make this code better i'd really appreciate it.
rox on
nick bernard
'not the entire script, just some variable definitions and subroutines
'variables
SYMBOL· d0····· =BIT0
SYMBOL· d1····· =BIT1
SYMBOL· d2····· =BIT2
SYMBOL· d3····· =BIT3
SYMBOL· d4····· =BIT4
SYMBOL· d5····· =BIT5
SYMBOL· d6····· =BIT6
SYMBOL· d7····· =BIT7
SYMBOL· d8····· =BIT8
SYMBOL· d9····· =BIT9
SYMBOL· d10···· =BIT10
SYMBOL· d11···· =BIT11
SYMBOL· d12···· =BIT12
SYMBOL· d13···· =BIT13
SYMBOL· d14···· =BIT14
SYMBOL· d15···· =BIT15
SYMBOL· door··· =B0
'subroutines
SHIFT_IN:
·· PULSOUT SR_LOAD,1
·· d0 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d1 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d2 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d3 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d4 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d5 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d6 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d7 = SR_INPUT
RETURN
SHIFT_OUT:
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· PULSOUT SR_LATCH,1
RETURN
SO_BIT:
· IF d0 = 1 THEN LED_ON
· LOW 7
· GOTO SHIFT
LED_ON:
· HIGH 7
SHIFT:
· PULSOUT SR_OCLK,1
· door = door/2
RETURN
rox on
nick bernard
'variables
SYMBOL· door··· =B0
'subroutines
SHIFT_IN:
·· d0 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d1 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d2 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d3 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d4 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d5 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d6 = SR_INPUT
·· PULSOUT SR_CLK,1
·· d7 = SR_INPUT
RETURN
SHIFT_OUT:
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
·· GOSUB SO_BIT
RETURN
SO_BIT:
· LOW 7
· GOTO SHIFT
LED_ON:
· HIGH 7
SHIFT:
· PULSOUT SR_OCLK,1
· door = door/2
RETURN
' iobyte is the byte to shift in or out
datapin con 15
datainput var in15
clkpin con 14
i var byte
iobyte var byte
shiftoutput: ' sends iobyte
output datapin
for i=0 to 7
· ' Set data pin to 0 or 1
· low datapin
· if (iobyte & $80) <> $80 then so0
· high datapin
so0:
· iobyte=iobyte*2 ' shift byte left
· high clkpin
· low clkpin ' could use pulsout
next
return
shiftinput:
input datapin
iobyte=0
for i=0 to 7
· iobyte=iobyte*2 ' shift left
· iobyte=iobyte | datainput
· high clkpin
next
return
Of course, you could rearrange this to shift right pretty easily.
Al Williams
AWC
Add Floating Point Math to your Stamp
http://www.awce.com/pak12.htm
i considered a nested shifting function. but i was hoping for a way to adress the bits of the byte like values of an array. oh me
rox on
nick B
Shift_Out:
· FOR shift = 1 TO 8··········' shift 8 bits
··· SData = Bit7··············'·put MSB on·data pin
····PULSOUT Clk, 1············' clock the bit
····temp = temp * 2···········' get next bit
· NEXT
··RETURN
This code does an MSBFIRST shift -- you can change the Bit7 reference to Bit0, and divide temp by 2 instead of multiplying.· It's probably obvious, but the variable "temp" is aliased to B0.
Jon Williams
Dallas Office
