TRIAC and Stamp Pin
How do I switch a 24-volt AC inductive load using a TRIAC and a Stamp pin?· The solenoid's inrush current is about 800mA and the sustain current is around 300mA.· I don't want to use a relay.· Could someone post a diagram and part numbers?
Thanks.
Thanks.
2. Buy a 5-volt regulator (radio shack) and then use L.E.Ds to rectify (also radio shack)
_________
+24V≈ >----P1-| | __ |
Gnd >
P2-| +5v| (_) |
/P3-|_Reg|____|
\_____^^^---|>|-> Out +5v DC
\-->Gnd
***Key*** |
^^^ = Resistor |
() = Capacitor |
- / \ |= Wire |
Resistor = 10K |
Capacitor = |
Small and Non-|
electrolic |
Stamp Pin ---> Optical Isolator ---> Transisor ---> Triac
configuration.
Chris
Post Edited (Orion) : 10/8/2004 12:53:41 AM GMT
Have you ever (or do you know how) to use the Stamp with triac, at less than 100% level?
That is, I want to do fire the triac at certain phase angle, like a light dimmer.
Any idea?
Thanks.
