Is there a connector for a servo or ESC? — Parallax Forums
xmanxman Posts: 1
edited 2004-10-07 15:32 in Robotics
Is there a regular 3-pin female for this or do·I have to·just use one of the i/o pins and hook it to + and gnd? Kind of messy. I was hoping for a connector.
  • Jonny555Jonny555 Posts: 46
    edited 2004-10-07 01:21
    R/C hobby shops usually sell connectors of all types. There are many online sources for quality connectors.
    Post Edited (Jonny555) : 10/7/2004 3:10:34 AM GMT
    Usually Servo's are intended to be installed in an RC airplane or as an RC automobile control. As such, they have a short 3-wire connector intended to be plugged on to pins sticking up from a circuit board.
    You can make a connector to use with these. I believe it is the smallest 'molex' type connector. They make two flavors of pins -- one with a female socket, one with a pin already attached.
    You MIGHT be able to find pre-fabricated 'Servo Extension' cables. Check HobbyWorks.com in their aviation section.
