eeprom verify error #204
hi guys
·anyone know what the error "eeprom verify error #204" message could be caused by?
some background, the error was displayed 3% into the download of the first page of a multipage program designed for the bs2p40.·i have·downloaded to the same chip/board/cable/pc many times during my development of the program and the mods to the program amounted to moving the displayed chars on a lcd so i cant see how the fault could lie in the code·besides the program tokenises correctly.
thanks in advance .
thanks in advance .
but take a look for cause of problem before replace EEPROM
- check power supply. Is 5 V.DC. correctly? if error more than 15%, stop and check it.
- is there any heavy load connect on board? such as relay or motor or LED backlight on LCD .. if yes, disconnect them and try again.
- look on 24WC128 pins' was mounted firmly? any pin crack?
some other cause..
- you connect Stamp with direct COM port or using USB to Serial converter?
- lifetime was come..!
no load added all outputs dissconnected
i have looked at the legs/pads/tracks through a magnifying lense and cant see any problems
com port is a direct connection to pc not using usb to serial conversion. although i have tried it on another pc using a usb to serial converter with the same results.
as for its lifetime, its only a week old.
thanks worapoht for your help
any other ideas
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
·thanks for your time
thanks to the lads who tried.
