BS2 programming problem?
Sorry if this has already been asked, but I'm having problems programming my BS2.
I made a cable and it worked with my old laptop, but my laptop died and it doesn't seem to be working with my desktop.
When I try to program it says loop back ok, echo ok, then No Basic Stamps found.
The program that I previously loaded on the BS2 seems to be running, so I think the BS2 is ok.
I've tried playing with the COM ports FIFO buffer settings, but that didn't help.
Any suggestions?
Dylan
Any suggestions?
Dylan
Well... it was working fine when I made that first post. Since then, I've continued to fiddle with it and I now I've really broke it.
After trying a few things, I plugged the battery pack back in (it is a polarized plug) and there was a small flash and pop from what I'm pretty sure is the voltage regulator. I removed the BS2 from the breadboard and it looks like the trace that connects pin 23 and pin 4 has burnt in half.
I'm not sure exactly what went wrong. Because pin 4 is the ground that is hooked up to the serial port I would think that it was someing wrong with the cable, but I've triple checked the pinouts and this cable worked before on my laptop. Maybe I induced a short on my bread board while playing with it and I'm just not seeing it, or maybe there is a short in my computers serial port.
Oh well.
Dylan
Do you use one of the Standard Parallax boards? If so, why don't you use a standard female to male serial cable? It would be much more easy and more SAFE !!!
And by the way, which connectio between pins 23 and 4 do you mean?, the one on the top side of the chip?. They are both VSS (=ground). Is there something wrong with your power supply???
Regards and I'll pray for your chip,
Klaus
My power supply is a 2 cell Li-Ion battery pack. It has a connector that only plugs in one way so I know I didn't plug the battery in backwards.
I still don't know what I did, but I'm pretty sure that the chip is dead now.
Dylan
If you only damaged the ground track of the BS2, which is possible depending on how your grounding wires go in your circuit, then there is a (small) chance that the BS2 still works when you connect pin 23 and pin 4 externally.
Give it a try before you give up
Succes,
Klaus
After hooking up an external regulator the program that was loaded on the stamp works again.
I looked at the DTR signal on the serial connector and it had 0V and according to the stamp manual it is supposed to have -12V. I hooked the stamp up to a different computer and it programs fine.
I guess the serial port on my other computer is broken. It is my beater computer in the garage and I have done a lot of stupid things on it, so it isn't that surprising.
Thanks for the suggestions.
Dylan
