What am I doing wrong.....Probably everything!
I am having problems with converting this program to a LCD Display. The Debug portion of this works perfectly, but the Azimuth will only go around 240 degrees and the look up table acts different. That is why I added the lower lookup table. Ay help would be appreciated....
'{$STAMP BS2}
E CON 0 ' LCD Enable pin (1 = enabled)
RW CON 2 ' LCD Read/Write pin (1 = write)
RS CON 3 ' Register Select (1 = char)
WPIN CON 8 ' Anno Input
ADDATA CON 9 ' A/D data line
ADCLOCK CON 10 ' A/D clock
ADREAD CON 11 ' ADC vout
RESULT VAR BYTE ' Result of conversion
AZIMUTH VAR WORD ' Compass read 360 degrees
M VAR BYTE ' degress divided by 45
A VAR byte ' Lookup First compass indicator
B VAR BYTE ' Lookup Second compass indicator
WIND VAR BYTE
WINDACC VAR WORD ' Accumulation for average
WINDMAX VAR BYTE ' Maximum wind speed
NSMPL VAR WORD ' number of samples
LCDddir VAR DirB ' port direction
LCDout VAR OutB ' 4-bit LCD data out
LCDin VAR InB ' 4-bit LCD data in
ClrLCD CON $01 ' clear the LCD
DDRam CON $80 ' Display Data RAM control
CGRam CON $40 ' Custom character RAM control
LINE1 CON $00
LINE2 CON $40
char VAR Byte ' character sent to LCD
CHAR2 VAR BYTE
addr VAR Byte ' address to write to / read from
addr2 VAR Byte ' address to write to / read from
index VAR Byte ' loop counter
tOut VAR Byte ' test value to write to LCD
tIn VAR Byte ' test value to read from LCD
temp VAR Word ' temp value for numeric display
FLAG1 VAR NIB
FLAG2 VAR BYTE
FLAG3 VAR BYTE
width VAR Nib ' width of number to display
DirL = %11111101 ' setup pins for LCD
GOSUB LCDinit ' initialize LCD for 4-bit mode
MAIN:
GOSUB AD:
WINDACC=0
COUNT WPIN,2250,WIND ' Frequently, e.g. once per 10 seconds
WINDMAX = WIND MIN WINDMAX ' Maintains Maximum Windspeed
WINDACC = WINDACC + WIND ' Infrequently, only when it is time to log data
NSMPL = NSMPL+1 ' One more sample
AZIMUTH = RESULT */360 ' Compass read 360 degrees
M = AZIMUTH +22 // 360 /45 ' degress divided by 45
LOOKUP M,[noparse][[/noparse]"N","N ","S","S","S","E","N "],A ' Lookup First compass indicator
LOOKUP M,[noparse][[/noparse]"O", "W","W","W","O","E"," E"],B ' Lookup Second compass indicator
DEBUG HOME
DEBUG " GUIDO'S MIRAGE",CR
DEBUG SDEC WINDACC," WIND SPEED ",CR
DEBUG SDEC WINDMAX," MAX WIND SPEED ",CR
DEBUG A,B ," WIND DIRECTION ",CR
DEBUG SDEC AZIMUTH," COMPASS WIND INDICATOR ",CR
PAUSE 500 ' pause between readings
char = ClrLCD ' clear the LCD
GOSUB LCDcommand
IF FLAG1=0 THEN BB:
IF FLAG1=1 THEN AA:
BB:
FOR index = 0 TO 55 ' create display
pause 50
LOOKUP index,[noparse][[/noparse]"WIND SPEED COMPASS DEG: "],chAR
GOSUB LCDwrite
NEXT
FLAG1=1
ADDR=WINDACC ' create address (0 to 63)
ADDR2=AZIMUTH
GOTO GG:
GG:
ADDR=ADDR
GOSUB LCDwrite ' move the value to CGRAM
char = CGRam + addr ' set CGRAM pointer
GOSUB LCDcommand
char = DDRam + 13 ' show address at position 13
GOSUB LCDcommand
temp = addr
width = 3
GOSUB PutVal
ADDR=ADDR2 ' create address (0 to 63)
GOSUB LCDcommand
char = DDRam + LINE2 + 13 ' show address at position 13
GOSUB LCDcommand
temp = addr
width = 3
GOSUB PutVal
GOTO MAIN ' do it again
END
PutVal:
FOR index = (width - 1) TO 0 ' display digits left to right
char = (temp DIG index) + 48 ' convert digit to ASCII
GOSUB LCDwrite ' put digit in display
NEXT
RETURN
LCDinit:
PAUSE 50 ' let the LCD settle
LCDout= %0011 ' 8-bit mode
PULSOUT E,1
PAUSE 5
PULSOUT E,1
PULSOUT E,1
LCDout = %0010 ' 4-bit mode
PULSOUT E,1
char=%00101000 ' MULTI LINE
GOSUB LCDcommand
char = %00001100 ' disp on, crsr off, blink off
GOSUB LCDcommand
char = %00000110 ' inc crsr, no disp shift
GOSUB LCDcommand
RETURN
LCDcommand:
LOW RS ' enter command mode
LCDwrite:
LCDout = char.HighNib ' output high nibble
PULSOUT E,1 ' strobe the Enable line
LCDout = char.LowNib ' output low nibble
PULSOUT E,1
HIGH RS ' return to character mode
RETURN
LCDread:
HIGH RS ' data command
HIGH RW ' read
LCDddir= %0000 ' make data lines inputs
HIGH E
char.HighNib = LCDin ' get high nibble
LOW E
HIGH E
char.LowNib = LCDin ' get low nibble
LOW E
LCDddir= %1111 ' return data lines to outputs
LOW RW
RETURN
return
AD:
PAUSE 100
LOW ADREAD
SHIFTIN ADDATA,ADCLOCK,MSBPOST,[noparse][[/noparse]RESULT\9]
HIGH ADREAD
PAUSE 100
RETURN
AA:
FOR index = 0 TO 54 ' create display
pause 50
LOOKUP index,[noparse][[/noparse]"WIND DIRCT: COMPASS DEG "],chAR
GOSUB LCDwrite
NEXT
IF A="N" THEN N:
IF A="S" THEN S:
IF A="E" THEN K:
IF A="W" THEN W:
A2:
ADDR2=B
IF B="N" THEN N1:
IF B="S" THEN S1:
IF B="E" THEN K1:
IF B="W" THEN G1:
IF B="O" THEN O1:
FF:
FLAG1=0
FLAG2=0
FLAG3=0
GOSUB LCDinit
GOTO MAIN
HH:
GOSUB LCDcommand
char = DDRam + 10 ' show address at position 13
GOSUB LCDcommand
temp = addr
width = 3
GOSUB LCDWRITE
N:
GOSUB LCDcommand
char = DDRam + 14 ' show address at position 13
GOSUB LCDcommand
temp = addr
width = 1
CHAR=78
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
S:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=83
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
K:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=69
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
W:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=87
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
N1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=78
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
S1:
GOSUB LCDcommand
char = DDRam + 15 ' show address at position 13
GOSUB LCDcommand
temp = addr
width = 1
CHAR=83
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
K1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=69
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
G1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=87
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
O1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=79
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
'{$STAMP BS2}
WIND VAR BYTE
LINE1 CON $00
LINE2 CON $40
CHAR2 VAR BYTE
FLAG1 VAR NIB
FLAG2 VAR BYTE
FLAG3 VAR BYTE
MAIN:
GOSUB AD:
WINDACC=0
DEBUG HOME
GOSUB LCDcommand
IF FLAG1=0 THEN BB:
IF FLAG1=1 THEN AA:
BB:
pause 50
GOSUB LCDwrite
NEXT
FLAG1=1
ADDR2=AZIMUTH
GOTO GG:
GG:
ADDR=ADDR
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 3
GOSUB PutVal
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 3
GOSUB PutVal
END
PutVal:
NEXT
RETURN
LCDinit:
PULSOUT E,1
PAUSE 5
PULSOUT E,1
PULSOUT E,1
PULSOUT E,1
GOSUB LCDcommand
GOSUB LCDcommand
GOSUB LCDcommand
RETURN
LCDcommand:
LCDwrite:
PULSOUT E,1
RETURN
LCDread:
HIGH RW ' read
HIGH E
LOW E
HIGH E
LOW E
LOW RW
RETURN
return
AD:
PAUSE 100
LOW ADREAD
HIGH ADREAD
PAUSE 100
RETURN
AA:
pause 50
GOSUB LCDwrite
NEXT
IF A="N" THEN N:
IF A="S" THEN S:
IF A="E" THEN K:
IF A="W" THEN W:
A2:
ADDR2=B
IF B="N" THEN N1:
IF B="S" THEN S1:
IF B="E" THEN K1:
IF B="W" THEN G1:
IF B="O" THEN O1:
FF:
FLAG1=0
FLAG2=0
FLAG3=0
GOSUB LCDinit
GOTO MAIN
HH:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 3
GOSUB LCDWRITE
N:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=78
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
S:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=83
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
K:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=69
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
W:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=87
GOSUB LCDWRITE
GOTO A2
PAUSE 500
GOTO MAIN
N1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=78
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
S1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=83
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
K1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=69
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
G1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=87
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
O1:
GOSUB LCDcommand
GOSUB LCDcommand
temp = addr
width = 1
CHAR=79
GOSUB LCDWRITE
PAUSE 500
GOTO FF:
What type of LCD are you using? HD44780 or compatible?? You use 3 bit for control but do you use 4 bit for data??
Your code is so long that I did not really find this. Maybe you can cut out and show the pieces of importance to the problems you have to improve readability a bit.
Klaus
·· I agree with Klaus, you should probably post the relevant parts of the code...I have converted many DEBUG display routines to LCD, and I can't follow real easy what you're doing in the code.· Mainly because most of your labels are 1 or 2 letters which isn't very descript...I will offer you this though...When converting directly from the DEBUG statements to the LCD, you can run into problems the way you're going about it when you were using DEBUG modifiers.· These won't work exactly the same when you're outputting the data to the LCD via 4-bit parallel mode without seom extra work.· If you were using a serial LCD, or had a serial backpack, it would be much easier, since you could use the modifiers in the SEROUT command as well.· This would keep the proper formatting and display of numeric values the way they worked before.· Using a serial backpack or display will also add a small bit of cost, but it will also save I/O lines on the BS2...Here are 2 I have used:
http://pic-an-lcd.com/·· (A little pricey)
http://www.phanderson.com/lcd106/lcd106.html· (Better pricing, but less tech support)
I use these chips in all my BS2 applications that involve the LCD (Except the mouse trap).
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Thanks Again
Knight Designs
P.O. Box 97
(607) 535-6777
I would really appreciate that. Also in the Stamp Works manual they show terminating the DB4-DB7 to I/O pins.....Why? There is no programming for those pins?
Again
Thank You Very much!!!
But there really SHOULD be a fairly large bunch of code handling DB4-DB7 on a BS2 with the HD44780 LCD controller !!!
I think Chris will show you that code, if not then I have similar LCD-code here.
Regards and succes,
Klaus
First of all Thank you for all your help. Again I have done a lot of reading and maybe I am totally confused as normal. The LCD is HD44780 compatable. I have no terminations on DB4-DB7. If you check my original supplied program I am only using:
I am having no problems displaying Wind Speed, Max Speed. The Azimuth seems to only respond for 240 degrees instead of 360. There is no dead band. I would really appreciate if a sample code or what the heck I might be doing wrong. When I went into the Stamp Work book they show that DB4-DB7 are connect to I/O, But they show now programming for those I/O.
Again Thank You
Guido
Guido,
·· First of all I guess I didn't catch this before, but in 4-bit mode on Hitachi controllers it's the DB4-DB7 pins that you're using in 4-bit mode.· I don't kno which ones you were going to connect, but as a minimum to control the LCD you need at least 6 pins.· DB4-DB7 for data, the RS line, and the Enable line (E).· You don't need the R/W line as you can tie it low (As long as you adhere to timing of writes to the display).· I suppose most people would say to ground DB0-DB3, however, in many 4-bit applications I have seen these simply left floating.· My guess would be that the controller pulls them low, although I can't say without referencing my tech sheet, which is at the shop.· I suppose if you want to be on the safe side, ground them.
·· As for writing to the display in 4-bit mode, you must first write the high nibble, then the low nibble.· It would be something like:
LCD_Out:
··· OUTC = data >> 4
··· PULSOUT 6, 1
··· OUTC = data
··· PULSOUT 6, 1
··· RETURN
Where your LCD DB4-DB7 is connected to BS2 pins 8-11, respectively, and the Enable line is connected to pin 6 on the BS2.· To send commands, you would first bring the Register Select Line LOW, call the routine above, then bring the RS line HIGH.· Of course, I do have code for this, but it's at the shop, and I will be there tomorrow and send it.· Hope this helps for now.
Knight Designs
P.O. Box 97
(607) 535-6777
Thank you again for your help. I would appreciate you sending me that information. The thing that I am still puzzled about is there is no code, or identification for DB4-DB7...Guess what I am saying, It appears this is the Data area, but how does the Stamp know that? What is actually being done with these pins. I apologize for being a newbee, but I really love the challenge of learning something new and useful, and I am finding out that this forum provides the help regardless of should I say stupidity!!
I want to apologize to Buck Rodgers about my post. Again being new, I have to learn the process of this forum. I give everyone who has helped a big thank you.....Trust me someday it will make sense.
Thanks Again Chris
Guido
The Stamp doesn't have to know aobut DB4-DB7 since those are external connections; but you as a programmer know what they are. Chris's example above is a good one in that OUTC becomes DB4-DB7.
Jon Williams
Dallas Office
·· I think (In retrospect) that I got the code (Or at least it's framework) from either one of Jon's articles, or an older Parallax document.· I say this because I am home, and all I have left on this computer is code-snippets I was testing years ago to port some of my Z80 routines onto the BS2.· At the time if Parallax already had code to do something, I modified it (If needed) to my application and used it (No sense re-inventing the wheel).· However, I was going to suggest downloading the Stampworks manual from Parallax:
http://www.parallax.com/dl/docs/books/stampworksmanual.pdf
It has a very similar example for using the LCD in 4-bit mode, and maybe looking at it will help you understand it better.· If not, let us know and we'll try to elaborate.· But generally speaking, using the LCD on the stamp is really quite easy once you've done it a couple of times...Which is why back when I got into the BASIC Stamp, I tried almost all of the experiments in the Stampworks manual before I tried any large projects, and I created a code-snippet library from the Parallax source of things I thought I could use in my routines.· Of course, credit is always give where it is due, and I am almost positive that the LCD code I quoted above came from one of Jon's earlier writings...Even as a programmer of 20+ years, starting with a new CPU/MCU can be tough.
Anyway, good luck on it!
Knight Designs
P.O. Box 97
(607) 535-6777
Post Edited (Chris Savage) : 10/3/2004 9:06:10 PM GMT
Klaus
