Convert "string" to number
I have a received some data via seriel interface.
The data is stored in an array (MSG \8)
The data is always nummeric. ie 00000360
the first 4 chars·is always 0
How do i convert the last 4 chars to a numeric word ie 360·??
Kind regards
Anders
Kind regards
Anders
for x = 3 to 0
debug dec(x) ? data
next
i'm not too sure about that one - you'll have to try it.
Sid Weaver
Try the Stamp Tester
This gives an error
SERIN PinRx, Baud,Bad_Data,5000,no_data , [noparse][[/noparse]WAIT("," ),SKIP 1, dec8 limit ]
This doesnt work:
SERIN PinRx, Baud,Bad_Data,5000,no_data , [noparse][[/noparse]WAIT("," ),SKIP 1, dec limit ]
Anders
Try this:
serin pin, baud, 5000, no_data, [noparse][[/noparse]WAIT(","),· dec8 limit]
I don't think you can use Bad Data and no data in the same command.
Sid Weaver
if you are still having trouble, did you check your baud rates?
Sid Weaver
Assuming that you're successfully receiving the string (of eight characters), here's how you can extract the last four characters as a numeric value:
Get_Value:
· value = 0
· FOR idx = 4 TO 7
··· value = value * 10
··· value = value + (msg(idx) - "0")
· NEXT
· RETURN
Jon Williams
Dallas Office
Post Edited (Jon Williams) : 9/30/2004 10:12:40 PM GMT
Sid
msg············ VAR···· Byte(8)
idx············ VAR···· Nib
value·········· VAR···· Word
Reset:
· DEBUG CLS, "Enter a value (8 digits): "
Main:
· DEBUGIN STR msg\8
· value = 0
· FOR idx = 4 TO 7
· NEXT
· DEBUG CRSRXY, 0, 2, DEC value
· END
Jon Williams
Dallas Office
//akj
