touch screen with ir and bs2?
I'm a sculpture grad looking to create a huge, possibly 10 feet by 6 feet transparent touch screen without mortaging the house. I was thinking of somehow using multiple x y ir detectors and running those to the basic stamp. I want to have "objects" projected on to the screen and when the viewer touches their finger/hand to the screen it will change, just like an atm or wedding registry machine, only bigger. Real touch screens use transparent pressure sensitive conductors so if anyone knows about this that would be helpful too. I have very little electrical knowledge, so any suggestions, please dumb it down. Any ideas on how I might do this the easiest and cheapest way? thanks! mark
Jon Williams
Dallas Office
There are several ways of doing this. One is to have an 'X' axis emitter, and a 'Y' axis emitter. Then you put a whole lot of recievers in holes along the frame. When the 'X' emitter is on, check the 'shadow' of the person's finger against the receivers. Of course, the 10' distance makes this a problem, for anything except MAYBE a laser-emitter.
I suppose the 'shadow' cast by a laser would have as little scatter as the laser itself, so that might be ok. Still, a finger is a hard thing to sense.
