how do I write this code?
I want to write code for a paintball gun and have no clue how to do it..
Also ill be usin a bs2
Basically what I want it to say is:
' When powered up it is ready with these instructions:
Main:
' Have pin 5 activated because its the led light and has to be on at all times when powered up
If in0 = 1 then 'in0 = trigger
High 1 ' activated solenoid
Pause 10
Low 1 'deactivates solenoid
Pause 40
Goto main
' At any point in the main code if the pin 0 is held in/activated for 2 seconds it goes into mode1
Var mode1 byte
Mode1:
' When in mode1 also have pin 5 activated because it the led light
' This mode has beam break eyes (emitter and detector)(emitter = pin 2, detector = pint 3), when the beam is broking it lets readyloop know its okay to fire. If beam isn't broken then it can't fire and that loops
'This mode is the same as firing mode but has debounce 0
'Mode1 also has to say if the pushbutton in pin 4 is pressed at anytime it goes into MAIN code
End mode1
' At anytime if the pushbutton in pin 4 is pressed at anytime it goes into MAIN code
Main:
Pause 10
Pause 40
Goto main
Var mode1 byte
Mode1:
End mode1
