Servo Power Problem
I have recently been playing around with a servo with my BS2e. When I attach the servo to my circuit and tell the program to run (using the same program as given in the pdf. file) the BS2e board·overheats. Do you·guys run the servos off the Vdd given by the stamp board or do you use an external power source·for the servos?
Thanks·
Thanks·
You CAN power the servo from Vdd, but as you saw, a servo takes a bit more current. You aren't trying to run the servo off the BS2e module's regulator, are you? At the very least, you need an external regulator (like a 7805 or 3840-5) for this to work at all.
Since I needed the basic stamp to work on important things, I opted for a seperate servo controller. I couldn't find a MiniSSC-II anywhere so I picked up a great servo controller, the Parallax servo controller(PSC). This module is sweet, blinking lights and all. It has way more channels then i need(16) but maybe someday it will·be recycled into something that will require the extra channels.
Jonny
Post Edited (Jonny555) : 9/29/2004 1:56:20 AM GMT
