TAOS tcs 230
[font=Arial,Bold size=1]On June 2003, Jon Williams had an article about this kit- "Color me Tickled". ·I read the column, but I would like to go little further on this. Does anybody have an idea how to expand the project and use 2 kits which will take the reading from two different parts (lighting might be different from one to the other) and compare the colors. The two parts are supposed to be the same color, but sometimes by mistake, are mixed. Therefore, I have a product with one component one color and the other component is a different color. I would like to know if it is a way to expand the same project, using one stamp, and take a decision: parts are the same color or parts does not match, then identify one color from three possible· choices.
·Thank you[/font][font=Arial,Bold size=5]
[/font]
[/font]
A marked difference in the light falling on the two components might cause some problems but using the TCS230 Color sensor from parallax would probably solve that problem.
Sid Weaver
Try the Stamp Tester
The component are the same color from the same paint boot. The only problem is that they put one component grey and the other black . Two color sensors on the same stamp must see that and the stamp has to make the decision; pass or fail.
Can you guide me how to do it ? Also, if the colors match , the stamp should tell me what color it is from 3 choices.
Jon Williams
Dallas Office
